Painting Deck and Cockpit....DIY or Pay? - Page 2 - SailNet Community
 5Likes
post #11 of 12 Old 05-23-2019
Re: Painting Deck and Cockpit....DIY or Pay?
It is a LOT of detailed work to get the job done right. On the other hand, to get a shop to do it properly, that means an enclosed climate controlled EPA-sanctioned paint booth, and that's gonna cost. Anyone who says they can do the job outside without that? Yeah, good from 50 feet, good from 25 feet, any closer and you'll see the bugs and fluff that came in the wind while they were working.
The materials aren't cheap, no matter how you do it. If you try to mask off hardware, plain masking tapes become iron after a couple of days in the sun. The green or blue ones may remain pliable for a week. One guy working on one deck? You need the 3M silver masking tape, about 4x the price, but it can be removed after 30 days without fighting. And you won't find that at the big box stores.
The paints (excuse me, "coatings") tend to be sensitive to temperature and humidity, so you need to practice under the same conditions that you'll be working under. It can be a very satisfying job--but you will need some practice, a LOT of sandpaper and prep fluids, and a good respirator and eye protection and other things. Plus, a place to work. Many yards won't allow the painting and sanding.
But if you've got the time and place, and are willing to practice the skills, you can spend a lot less than what a proper climate-controlled paint shop is going to charge. Having a reliable helper, who can roll and tip along with you, or help un/blot deck hardware from the other side, is really important too.
FWIW I think the extra time and effort to remove all hardware and rebed it, is worth more than any savings to be had masking things off.
hellosailor is offline
post #12 of 12 Old 05-23-2019
roverhi's Avatar
Do everything you can not to paint the deck and cabin. I had to paint mine because of many holes from old, no longer installed equipment. The paint job came out great but hasn't stood up to everyday use of the boat. Many scratches and wear points in the paint that were shrugged off by the gelcoat for four decades have appeared. Had sheet bags in the cockpit that I left in place for a couple of months only to discover the paint had blistered underneath them. Now remove them after each sail. The blisters have shrunk but not disappeared.
Paint was two part industrial polyurethane not a marine paint but have heard of similar problems from Marine paint suppliers.
MarkofSeaLife likes this.
roverhi is offline
Keel Grounding repair - DIY or pay for a profesional? thelemon Gear & Maintenance 13 09-11-2016 01:33 AM
Cockpit and Deck Painting Advice engineer_sailor Gear & Maintenance 32 03-09-2015 01:29 AM
Standing Rigging, DIY or pay a Professional? LandLocked66c Gear & Maintenance 14 07-20-2010 08:14 PM
Motor: DIY or Pay up; that is the question canoeman256 General Discussion (sailing related) 11 10-11-2008 06:16 PM
Boat Sales Tax - To Pay or Not to Pay? LyleRussell Boat Review and Purchase Forum 41 09-06-2007 11:19 AM
