Mast Oxidation and Protection - SailNet Community
 7Likes
post #1 of 12 Old 05-24-2019 Thread Starter
Is this oxidation and how do I get rid of it? Also, the mast is an anodized mast so I know I have to be careful to not remove the finish. I don't want to paint it because I don't want the hassle of having to repaint every few years. Also, advise on cleaning and polishing it protecting it etc. Thanks, PS Mast is down replacing all standing, running rigging and all turnbuckles.
sailforlife is online now
post #2 of 12 Old 05-25-2019
roverhi's Avatar
Re: Mast Oxidation and Protection
No picture so can't tell you if it's corrosion. You can wax the mast with auto polish to give it some protection. Insulate dissimilar metals and use TefGel/LanoCote/LocTite for all fasteners. Be sure the drain holes at the base of the mast are clear so no water can pool inside the mast. The mast on my Pearson 35 is almost 50 years old and still looks good.
sailforlife likes this.
roverhi is online now
post #3 of 12 Old 05-27-2019 Thread Starter
post #4 of 12 Old 05-28-2019
Pessimistic guess is that the sails or lines have chafed the mast enough to remove the anodizing in those areas.
Optimistic guess is that it is something staining on the most, in which case some time with solvents or mild auto polish or white compound might take it off.
But if that's the anodizing worn through, you may it very difficult to transport a mast to anyplace that can still strip and re-anodize something as long as a mast. Which could make it paint time. You might want to ask around and find out just how where you'd need to send it, and what that would cost you.
hellosailor is offline
post #5 of 12 Old 05-31-2019
roverhi's Avatar
Aluminum self heels against oxidation/rust. The aluminum forms a protective layer of oxide that prevents further corrosion. The oxide is rough and doesn't look all that good but it doesn't affect the strength or long term health of the mast. Anodizing is essentially a controlled oxidation that doesn't have the rough and blotchy surface of the organic oxidation. If you can't live with the mast's current appearance you can paint it but you will be subjecting yourself to a lifetime of maintenance headaches.
post #6 of 12 Old 06-01-2019
SchockT's Avatar
I had a boat with a painted mast, and I did repaint it once in the time I had it. It looked great for years after the paint job, and I just did it with spraybombs in the back yard.
As long as you prep well and use a good paint, you can get a finish that will look good for many years. I don't think there is a huge amount of maintenance to be done, although you may find yourself painting again 10 years down the road to keep it looking good.
The important thing is to avoid chaffing. Your mast looks like it had halyards stowed to the base of the mast where they were free to chaffe and slap every time the wind blows.
Sent from my SM-G960W using Tapatalk
chef2sail likes this.
2011 Jeanneau 39i Azura
SchockT is online now
post #7 of 12 Old 06-01-2019
A lot of the maintenance on a painted mast seems to be caused by halyard slap. Karma, huh?(G)
jephotog likes this.
post #8 of 12 Old 06-01-2019
SchockT's Avatar
Yes, halyard slap is a pet peeve of mine, particularly if sleeping on board in a marina! I vowed many years ago that my boat would never be the source of such annoying sounds!
post #9 of 12 Old 06-02-2019
Emmalina
Steve Bateman's Avatar
Amusing how many people let there halyards slap it isn't goof for the halyard or the mast and if you live onboard you do whatever it takes to eliminate it !
Steve Bateman is offline
post #10 of 12 Old 06-02-2019
chef2sail's Avatar
I’m with you, pet peeve of mine also. It’s all about how/where you tie you halyards and in our case ez jack lines. Aside from the noise when your there, it bothers others and wears on your mast as evidenced by the OP
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
Cleaning oxidation off of sail hanks? ericb760 Gear & Maintenance 1 09-18-2013 08:39 AM
Removal of oxidation angiebear Gear & Maintenance 2 06-10-2009 03:57 PM
Gelcoat Oxidation Restoration Maine Sail Gear & Maintenance 11 04-23-2008 03:44 PM
Deck / Cockpit Oxidation question. MarkinPA Gear & Maintenance 2 07-18-2007 09:00 PM
Hull oxidation cholt40 Gear & Maintenance 1 01-10-2002 04:18 PM
