Keel Rash - SailNet Community
 4Likes
post #1 of 13 Old 06-05-2019 Thread Starter
1968 Columbia 50
SV Siren's Avatar
Keel Rash
Since the people on another forum have been of no help, I thought ya'll would be of better help.
Now that the rest of the bottom is finished, all I have left is to fix this fiasco. Please tell me if you think this is right or if you would suggest something else.
What I plan on doing is to grind back on either side of the keel bottom to good glass, which is encapsulated just as an FYI. I then plan on filling the couple of small void‘s which are there with West systems, followed by a half inch total =/- of glass mat. After that I plan on grinding it as fair as I can and then finishing off with thickened west systems epoxy and sanding to get the profile correct.
I do plan on putting down about six coats of Interlux 2000e barrier coat on top of this.
Does this sound about right, or would you suggest something better?
S/V Siren 1968 Columbia 50
SV Siren is online now
post #2 of 13 Old 06-05-2019
colemj's Avatar
Re: Keel Rash
Will you be more specific to what we are looking at? To me, it looks like the bottom of your keel, and it only looks like cracked/scuffed gelcoat - maybe from sitting on the keel in a cradle/ground or running aground or something?
If it is only gelcoat, I'd just grind it back to good, fair it, and be done. If this gets regular abuse, consider glassing on a strip of kevlar tape.
Otherwise, your plan sounds fine, if a bit overkill - but that depends on just what is happening in that picture.
Mark
SanderO likes this.
Dolphin 460 Catamaran "Reach"
Manta 40 Catamaran "Reach" - For Sale!
colemj is offline
post #3 of 13 Old 06-05-2019 Thread Starter
1968 Columbia 50
SV Siren's Avatar
Re: Keel Rash
Mark
It is the bottom of the keel, which is encapsulated. This is definitely from hitting something by the PO and runs the full length of the keel(10' or so). Some spots are 1/4" deep and are pin holes through to the keel. There are also slight gouges along the keel which I will just prep and fill/fair.
post #4 of 13 Old 06-05-2019
Above 5 knots
Dock
Re: Keel Rash
I'm with colemj, fair and forget.
I personally would use Interlux water tight epoxy filler, then paint and forget, but yeah, that's all.
MINI MOO, a 1983 Wavelength 24 - she's a fast cow!
SailingUphill is offline
post #5 of 13 Old 06-05-2019
JimsCAL's Avatar
Re: Keel Rash
If the damage is through to the ballast, then a proper repair is important. Especially if the ballast is iron, not lead.
olson34 likes this.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #6 of 13 Old 06-05-2019 Thread Starter
1968 Columbia 50
SV Siren's Avatar
Re: Keel Rash
Luckily it is lead...with just a few small penetrations about the size of a pencil. Thanks for the input.
post #7 of 13 Old 06-05-2019
overbored's Avatar
Re: Keel Rash
water proof filler and paint if you do add glass then use glass cloth cut on the diagonal it lays down around curves better than mat. most mat has binders that are not compatible with epoxy resin so the mat does not give good results. stay away from Kevlar it does not protect any better and if it does get damaged you will have a fuzzy mess on the bottom of the keel that can not be sanded. also think about using Pettit protect as the barrier coat as it only requires two coats to do the same thing as the 6 coats of 2000
"GOLD RUSH" PRINDLE 16
overbored is online now
The Following User Says Thank You to overbored For This Useful Post:
SV Siren (06-05-2019)
post #8 of 13 Old 06-05-2019
contrarian's Avatar
Re: Keel Rash
I suggest looking into soda blasting for this kind of work. Hand sanding is somewhat tedious
contrarian is online now
post #9 of 13 Old 06-06-2019 Thread Starter
1968 Columbia 50
SV Siren's Avatar
Re: Keel Rash
Thanks everyone for the replies..I appreciate it.
post #10 of 13 Old 06-06-2019
SanderO's Avatar
Re: Keel Rash
Your fix seems was over board... clean it , fill it with west, fair it... do your local barrier coat (not 6) and paint. Bottom of keels rest on stuff when the boat is hauled and block and will get beat up and these areas are hard to service.
pay attention... someone's life depends on it
SanderO is online now
