How to dissassemble this winch? - SailNet Community
 7Likes
post #1 of 19 Old 06-10-2019 Thread Starter
You can see in the attached photo there is a phenolic ring which prevents the roller bearings from sliding up. I can't see any non-destructive way to remove it. There is no screw in the winch socket. Presumably there is a spindle retaining key under the roller bearings, but I can't see it. This is a two speed winch on my 1986 Jeanneau, but the label is worn off. The second picture is the label of my one speed center board winch, presumably the same brand.
JohnBPrice is offline
post #2 of 19 Old 06-10-2019
Master Mariner
capta's Avatar
Re: How to dissassemble this winch?
I don't know that particular winch, but most I've worked on were very similar, I believe the ring will come up, probably being stuck down by old hard grease. Work it slowly and carefully (parts for that winch may be hard to come by) and it should come free. We use diesel as the cleaner.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #3 of 19 Old 06-10-2019 Thread Starter
Thanks capta, but the ring spins freely, it is under the teeth above it.
post #4 of 19 Old 06-10-2019
celenoglu's Avatar
There must be a way to remove the seat for the handle including the gear. After its removal the slipboard materal should come off and you can remove the bearings.
celenoglu is online now
post #5 of 19 Old 06-10-2019
Senior Moment Member
SloopJonB's Avatar
I'd guess the central spindle is retained under the base of the casting by a spirolock or snap ring something - you'll have to dismount the winch to access it.
MarkofSeaLife likes this.
SloopJonB is online now
post #6 of 19 Old 06-10-2019
SchockT's Avatar
That looks a lot like the old Lewmar winches I had on my old boat. Those winches could not be fully disassembled without unbolting it from the deck.
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #7 of 19 Old 06-10-2019
I vote with JonB and ShockT. If there's no visible way to remove the upper parts, then unmounting the winch probably will reveal they are secured from below. Since Beneteau owns Jeanneau, it is *possible* they'd recognize the winch and be able to confirm that for you.
hellosailor is offline
post #8 of 19 Old 06-10-2019 Thread Starter
Ah. Alas. I was afraid I might have to remove it, I was hoping someone might have some secret trick. Removing the starboard winch will be no problem, I can access it easily. The port side will require taking down a lot of the interior.
post #9 of 19 Old 06-10-2019
Administrator
Jeff_H's Avatar
Sorry, I probably should have read the post more carefully. I got distracted since I could not open the picture of the winch with the drum off.
Jeff_H is online now
post #10 of 19 Old 06-10-2019
al brazzi
If its free can you just lube it, no need to remove the bearing unless to replace it, but it doesn't sound like that's what you're trying to do.
albrazzi is offline
