Cape Dory, 1984 25D..limited restoration & relaunch. - SailNet Community
post #1 of 5 Old 06-11-2019 Thread Starter
Location: Live in Rock Hill SC, my 25D Cape Dory isc Moored in Mooresville NC on Lake Norman.
Recently purchased a 1984 25 D Cape Dory, engine has not been run for 4 years. Can anyone advise me on best procedure of what to do to the Varner 1MG diesel before I try to start it. I have replaced both oil & fuel filters. I will drain & refill fuel & oil. Do I pre oil cylinders, add injector conditioner to fuel, any thing I have missed or do not know about? Getting mildew & mold off (Cabin)wood work. Best sealer on wood especially teak on deck..
r wood work
Thanks
DDGIII
deeddg is offline
post #2 of 5 Old 06-11-2019
Re: Cape Dory, 1984 25D..limited restoration & relaunch.
I would hand crank the engine with kill switch engaged in order to lubricate it before start up. If this isn't possible I'd turn it over a couple times with the electric starter, kill switch engaged. That'll also do the trick.
Congrats on the boat, BTW. Those are neat old girls.
drew1711 is offline
The Following User Says Thank You to drew1711 For This Useful Post:
deeddg (06-11-2019)
post #3 of 5 Old 06-11-2019
overbored's Avatar
Turn the motor over by hand with the compression release open and the fuel shut off knob pulled out ( there is not kill switch on a 1GM ) to make sure it is turning properly then use the starter with the compression release open. then i would close the compression release and try to start it before you change the fuel filter . since you have changed the filter you will now have to bleed the fuel lines all the way to the injectors on an engine that you have not run. I would say read up on bleeding the fuel system or get a qualified mechanic to help you. https://www.yanmarshop.com/Media/Def...J020A1279).pdf
"GOLD RUSH" PRINDLE 16
overbored is online now
The Following User Says Thank You to overbored For This Useful Post:
deeddg (06-11-2019)
post #4 of 5 Old 06-11-2019 Thread Starter
Just opening up the fuel, new filter or not I have to bleed fuel lines? Every time I change fuel filters will this be an issue??
If I had done nothing with fuel/filter system I would not have had to bleed system..but risk contaminated fuel issue?
You have no idea how I appreciate this advise!!
deeddg is offline
post #5 of 5 Old 06-11-2019
overbored's Avatar
bleeding is not hard but read the manual first, diesels are very fussy about air in the fuel line not like a gas engine. you need to bleed before you turn it over. four year old fuel in the injectors should not be a problem. I have always used a outboard pump bulb to bleed the filters and lines. some will say they are not made for diesel and will fail. but I have never had a problem in 40 years
