Installing a Boomkicker...any tricks? - SailNet Community
 1Likes
  • 1 Post By SailingUphill
post #1 of 10 Old 06-15-2019 Thread Starter
NewportNewbie's Avatar
Defender had a sale on Boomkickers and I finally picked one up for my Santana 30. Any tips or tricks for the install? I have the added challenge of a rotating boom so I have to make it stationary, but besides that just wanted to know from others that have installed it if there is anything I should look out for.
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 10 Old 06-16-2019
Re: Installing a Boomkicker...any tricks?
The one that came with my boat was installed upside down. Kept popping out of clamps. Took a good amount of staring time to figure it out. So, don't install the brackets upside down. Other than that - just adjust to the resting position you like. It can take a hell of a lot of stress.
Ninefingers is offline
post #3 of 10 Old 06-16-2019
Freedom isn't free
Dock
catalina direct sells a lock for the boom to prevent rotation. I can't find it on their new site, I just know they sold one for the Capri 22, used it on my Capri 25, and it wasn't really necessary.
Boomkicker has some of the best customer service on the planet. Any questions you can email them, and they are quick to respond, and they have extra parts if you need them, will even do swaps for larger or smaller diameter rods.
The mistake that many make is they either shorten the rods to much, or use to large a diameter rods. Keep in mind this is not to replace your topping lift, but to provide upward force to allow you to shape the mainsail better, mostly in light air (add twist). It provides very little in the way of support of the boom in the meantime.
Freedom, a 1983 C&C 32 sailing Smith Mountain Lake, VA
SailingUphill is offline
post #4 of 10 Old 06-17-2019
Minnesail's Avatar
Is there a downside to using a boomkicker in place of the topping lift? It seems like it would work.
Their website says:
Boomkickers are simply the best solution to support the boom and eliminate the topping lift
Boomkicker
Catalina 22
on a starboard tack
Minnesail is offline
post #5 of 10 Old 06-17-2019
SchockT's Avatar
Their website says:
Boomkicker
Yes, I would agree that a boomkicker's primary benefit is to eliminate the need for a topping lift.
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #6 of 10 Old 06-17-2019
SchockT's Avatar
I don't think the swivel gooseneck on your boat will be an issue. I didnt even realize my Santana gooseneck was like yours until the vang was removed for repair. The rigid vang kept it from rotating. I suspect your Boomkicker will have the same effect. There is not a lot of torque placed on the boom under load.
post #7 of 10 Old 06-17-2019
Lake Sailor
cb32863's Avatar
When I installed mine, the directions were very easy. Just drilled, tapped, and screwed the pieces in place. Works great and yes, it removes the need for a topping lift.
Umquam Porro
Seeker 1992 Beneteau First 235
cb32863 is online now
post #8 of 10 Old 06-17-2019
overbored's Avatar
Their website says:
Boomkicker
last boat had one and we never had a topping lift. that is why they designed it, so you do not need a topping lift. we kept the main halyard attached to the end of the boom for storage to keep it away from the mast and the boom from bouncing when not using it.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #9 of 10 Old 06-17-2019
Freedom isn't free
Dock
Lemme rephrase... you cannot use the boomkicker as the ONLY support for your boom.
typically a topping lift or a halyard run aft of the boom holds the boom up when the sail is not hoisted. I always use a halyard, but then my boltrope is removed after each sail.
Otherwise an important handhold while under power alone goes away (as the boom won't support much weight under boomkicker alone).
Minnesail likes this.
post #10 of 10 Old 06-18-2019
Minnesail's Avatar
Ahh, good point. On a small boat like mine I do rely on the boom as a handhold when moving about the boat.
Catalina 22
on a starboard tack
