Worst boat project? - SailNet Community
 37Likes
post #1 of 36 Old 06-17-2019 Thread Starter
Worst boat project?
Upon completion of our bottom job my husband and I agreed that this was the absolute last time we were ever going to touch anti-fouling bottom paint in our lives. Calculated out the cost... stashing away $50 a month for 5 years (about how long we think we can make our hard bottom paint last) we'll have a pretty good chunk of change to just throw at a yard to get it done for us.
So...
Do you do your own bottom paint? Sanding? What type do you use?
And what is your worst boat project that you would never do again?
ABRsailing is offline
post #2 of 36 Old 06-17-2019
colemj's Avatar
Re: Worst boat project?
We hire out sanding now - done with that. I don't mind painting and can do it quickly and cleanly.
I won't do any detailing anymore. Tired of slinging a polisher over my head in the hot sun.
5yrs would be extraordinary life for any bottom paint, unless you are in a low-fouling area or hauled out part time.
Worst boat project is difficult to define. Some of the seemingly smallest, easiest stuff can turn into a nightmare of worst project ever. I just had to run a 10' wire through our overhead that turned into a 4-day swearathon and made my list of one of the worst jobs I've ever had to do.
Dirtiest, or most difficult, or most back-breaking are easier to define.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #3 of 36 Old 06-17-2019
It is a toss up between sanding the bottom and having to upgrade the transmission in the wife's Jeep to tow it.
The sanding is just a pain in the a$$. I wouldn't mind the trans work, but she doesn't let me drive it unless we are towing.
sailforlife likes this.
SeanM26 is offline
post #4 of 36 Old 06-17-2019
PhilCarlson's Avatar
Dock
That's easy. A while back a friend's young daughter pumped a baby wipe down the head.
I discovered it when the manual overboard pump seized up.
Fun fact: When this happens, the pump body is pressurized, resulting in little jets of blackwater as you loosen the screws.
Nasty, nasty, nasty, nasty, nasty.
PhilCarlson is offline
The Following User Says Thank You to PhilCarlson For This Useful Post:
sailforlife (06-17-2019)
post #5 of 36 Old 06-17-2019
TQA
Bombay Explorer 44
TQA's Avatar
How to make sanding the bottom much easier.
Buy an articulating drywall sanding head. This mounts on a pole. Get a 6 ft - 7 ft pole. Use 80 grit wet and dry.
Bucket of water with a drop of washing up liquid. You can now stand up with two hands on the pole and sand the bottom with long strokes dipping the head in the bucket to keep the work area wet. No bending down or working above your head.
I am a creaky old fart and there is no way I could hand sand the bottom working from below with the sanding block above my head. With this I can sand the bottom of my 44 ft mono in a couple of hours.
JimMcGee, SanderO, davidpm and 2 others like this.
TQA is offline
post #6 of 36 Old 06-17-2019
TakeFive's Avatar
This is exactly what I do, and it's every bit as easy as TQA says. Works great with ablative paint, but not so sure how well it would work with hard paint.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #7 of 36 Old 06-17-2019
SchockT's Avatar
I use ablative paint, and don't sand every time I paint. A good pressure wash, and a fresh coat of paint. Job done. I typically get 2-3 years out of a coat. Once in a while I do sand. Then I use a random orbital sander with a shop vac attached. While other guys in the yard ended up covered head to toe in paint dust, I ended up with a garbage bag full of paint dust!
As for the worst job...it has to be replacing the entire septic system in my last boat. The worst part was not the smell, it was replacing the hoses. They were routed through tight spaces, and any time they passed through a bulkhead or wood structure the holes were almost exactly the outside diameter of the hose. I spent hours contorted in tight spots, arms extended, moving hose 1/2" at a time. I was in pain for a week afterwards!
Sent from my SM-G960W using Tapatalk
JimMcGee and CalebD like this.
2011 Jeanneau 39i Azura
SchockT is online now
post #8 of 36 Old 06-17-2019
colemj's Avatar
This is also what I used to use, only I would use coarse drywall mesh screens instead of paper - they last longer and don't clog up.
However, I find that it is only good for light sanding. Basically prepping a good bottom for another coat. Actually removing any previous paint, or fairing out damaged paint requires more work than this allows.
Mark
- Current boat
- Previous boat
colemj is offline
post #9 of 36 Old 06-17-2019
I ripped out my traditional marine head and replaced it with a composting head. Installing the new head was pretty easy.
Removing the old head was inconceivably foul. This was after I'd tried my best to flush out the holding tank at the pump out station. I'm so glad I installed a composting head, as I never want to be anywhere near blackwater again.
BillMoran is offline
post #10 of 36 Old 06-17-2019
contrarian's Avatar
The worst boat project is whichever one you happen to be working on at the time.
That's just the way they roll.
CalebD and Tuna Driver like this.
contrarian is offline
