Is my mast straight - SailNet Community
 23Likes
post #1 of 22 Old 06-22-2019 Thread Starter
Is my mast straight
I had help raising my mast using a lift a few weeks ago. I had trouble getting the forestay to attach I had to loosen the back stay a bunch to lfinally get it hooked up then I had trouble getting the turnbuckle tight to pull the mast forward. I sprayed it with lube and left it at that.
Yesterday I was able to get the forestay tightened. I still can't tell if the mast is straight. I don't know if there is any more room to ease the back stay but can get there to check later today. I am thinking if I remember correctly I would need to tighten the back stay to ensure proper coverage of the threads.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is online now
post #2 of 22 Old 06-22-2019
Moderator
MarkofSeaLife's Avatar
Dock
Re: Is my mast straight
Yes, your mast is straight. Why is the horizon bent?
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #3 of 22 Old 06-22-2019 Thread Starter
By straight I mean vertical from boat.
Jordan
Oceanside CA
post #4 of 22 Old 06-22-2019
chef2sail's Avatar
Lol...Put down the rum Mark....l🙀🙀
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #5 of 22 Old 06-22-2019
roverhi's Avatar
You are going to have to launch the boat so it's floating on its natural lines to make a determination. Get a weight of some sort and tie it to the end of halyards that exit front and back of the mast. They will act as a plumb bob to tell if the mast is straight. Then you have to determine whether you want/need it straight. The angle of rake on the mast determines things like weather helm, raking the mast aft increases it, forward decreases it possibly to the point of lee helm. Have fun getting to know your boat.
roverhi is online now
The Following User Says Thank You to roverhi For This Useful Post:
jephotog (06-23-2019)
post #6 of 22 Old 06-23-2019
outbound's Avatar
Also prebend maybe what how manufacturer/N.A. built the boat so your main won’t shape correctly without it. Would look for further information as to if that’s required. Which one of your boats are you concerned about? The one in the pic?
jephotog likes this.
s/v Hippocampus
Outbound 46
outbound is online now
post #7 of 22 Old 06-23-2019
JimsCAL's Avatar
Mast does looked raked aft. Sounds like you have a problem with the forestay turnbuckle. Won't turn? How many threads are engaged?
JimsCAL is online now
post #8 of 22 Old 06-23-2019
Freedom isn't free
Dock
Ok prior owner here. So yep I'm the problem (I get it).
Mast should be raked, and it looks like it is, hard to tell with rotated pictures though. If you (in the water) hang a hammer from the main halyard in calm water, the total measured rake (at the boom level) should be about 3-5 inches away from the gooseneck.
What I wanna know is why you put 2 backstays on. The flicker cannot do its job if the original steel backstay is in place (the roach of the main catches on it). The purpose of the flicker and the amsteel blue 3/16 is so that when you release the cascaded backstay, it allows the light line to rise clear of the roach, with the steel backstay on there, it'll always be in the way, and wear the edge of the mainsail. No need to worry about the mast coming down the mainsail is up for this adventure and also the mast would stay up anyway as this is a highly swept spreader rig, and the mainsheet and mainsail would prevent it. Remove the steel backstay (unless I am seeing an illusion in the pictures).
For the record I am NO expert on the boat, but the guys at www.s279.org are.
The objective is for you to be able to ease the backstay (downwind) and allow the top of the mast to come up a bit, which requires the uppers to be ever so slightly lower in tension then the lowers. Given this you are flexing the top section of mast to create "bend" or release "bend" in that telephone pole of a mast (yeah it doesn't bend much), but it does make a huge difference in forestay sag. In the "really" light, like under 6 knots wind, you ease that backstay a lot to power up, and slowly add backstay as you get moving. But each tack you must ease the backstay almost completely so that fuller roached mainsail can clear the backstay without getting hung up. In over say 8 knots true, the mainsail won't catch and screw up your tacks, and its more important to keep forestay sag at a minimum to reduce heel.
So the procedure (for you and crew) is to call "ready about" on "aye" you ease backstay, start your tack, headsail flops to backwind, release genoa sheet, complete tack (turn)... overshoot close hauled to close reach, leave backstay off until you are 7/8 prior speed or so working your way back to close haul, and slowly adding backstay tension. In light air that tension shouldn't be much. You'll find in anything over 10 knots backstay has to be on through the tack, and over 15 knots on a lot and you'll start to see serious scallops in the mainsail halyard (halyard tension will likely need reset).
That boat will eat winds up to about 35 knots. If you drop down to the 105% you can sail with a reef and very little tiller. I found that boat to be extremely forgiving in nearly all points of sail, but it likes wind the most. Almost never sailed that thing with a reef, we just don't get enough wind on our lake for it, maybe a half dozen times or so, when winds were peaking over 25.
Freedom, a 1983 C&C 32 sailing Smith Mountain Lake, VA
SHNOOL is offline
The Following User Says Thank You to SHNOOL For This Useful Post:
jephotog (06-24-2019)
post #9 of 22 Old 06-23-2019
You have to be careful with the plumbob technique though. Some boats sit a bit of of level due to loading. I think it's more important that it's 90 degrees to the deck no? A three point laser level is handy. But not worth the cost for one time use. Grab a level and a straight bar to span your deck and make sure your boats sits flat. Or you can lay a four foot level across the toe rail at near the bow I suppose.
Edit, sorry my comments have more to do with side to side. Never mind.
Ninefingers is online now
post #10 of 22 Old 06-23-2019
overbored's Avatar
like Uphill said there is a tuning guide here https://www.s279.org/Documents/DoyleS279TuningGuide.pdf. Fore stay length is the first thing you set and then tune the rig. the backstay is for tuning while sailing
"GOLD RUSH" PRINDLE 16
overbored is online now
