Question about term used on boat listing - SailNet Community
 5Likes
  • 1 Post By Minnewaska
  • 4 Post By cb32863
post #1 of 8 Old 06-25-2019 Thread Starter
There's a boat in my marina that I looked up. In the listing it says in big letters "AS-IS, WHERE IS". That much I get.
What I don't understand is the other term: "Moisture in cabin top."
Does that mean that moisture has seeped into the fiberglass in the top deck?
Regardless of what the actual term means, how difficult is that kind of repair?
Captain Canuck is offline
post #2 of 8 Old 06-25-2019
Re: Question about term used on boat listing
It means moisture has gotten into the core material on the cabin top. Not an easy repair.
MarkofSeaLife likes this.
Jeanneau 54DS
Minnewaska is offline
post #3 of 8 Old 06-25-2019
rbrasi's Avatar
There are several threads about core repair that involve drilling and filling many holes. Look them up.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #4 of 8 Old 06-25-2019
Lake Sailor
cb32863's Avatar
Or just moving on to a different boat.
Umquam Porro
Seeker 1992 Beneteau First 235
cb32863 is online now
The Following User Says Thank You to cb32863 For This Useful Post:
john61ct (06-26-2019)
post #5 of 8 Old 06-25-2019 Thread Starter
Not buying, just curious as to the term. That explains why the boat is so inexpensive.
post #6 of 8 Old 06-25-2019
Administrator
Jeff_H's Avatar
As others have said, this probably means that someone put a moister meter on the deck and it came back elevated. It does not tell you whether the core is rotten or delaminated. Merely having an elevated moisture level may not mean much. Minimally it means that the deck fittings need to be rebed and ideally the fastening holes potted. But if the core is rotted or there is delamination, that is a much bigger job. That is where a knowledgeable, experienced, and skillful surveyor is important.
Jeff_H is online now
post #7 of 8 Old 06-25-2019
Moderator
MarkofSeaLife's Avatar
Dock
"AS-IS, WHERE IS".
Different usages depending on which country you are in.
It means the boat is for sale in the condition it is in now. Don't expect a price reduction because it's a 30 year old boat because it is a 30 year old boat. Go ahead and do a proper Survey... That survey is for you, and you alone. If you like the survey buy the boat. If you don't like the survey don't buy the boat but either way the price isn't changing.
In the USA it's a fear thing. In other countries it's normal
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #8 of 8 Old 06-25-2019
bell ringer
Don L's Avatar
Even if then cabin coring is wet doesn’t mean walk away from e boat. There’s the boat overall and price to consider.
My boat tested as having a wet core at the survey. Thing was at that spot it was solid fiberglass and not cored at all, itwas measuring a small void where a bulkhead was.
Don't blow air up my rear, be useful and blow it at the sails!
Don L is online now
