Windless Issues - SailNet Community
 1Likes
  • 1 Post By colemj
post #1 of 8 Old 06-30-2019 Thread Starter
davidpm's Avatar
Windless Issues
I took out a charter boat last weekend that had the windless pictured below.
It was wired in such a way so that the only way it would work is with the engine on.
I asked the briefer about how to drop the anchor if the engine fails.
He said something about using a winch handle but I tried that and the plug on top would come out but it was not clear what it does.
Does anyone know how this model works manually?
davidpm is offline
post #2 of 8 Old 06-30-2019
SanderO's Avatar
Re: Windless Issues
No idea David but that sure is a crazy design. Why wasn't the windlass mounted aft of the locker... maybe two lip doors... and have the chain run around the windlass and down into a hawser hole for the chain to drop inside the locker? Instead of a windlass hole there would be a windlass structure on the fore deck. I realize that this is not the question but I see many boats / complaints about inadequate provision for a windlass and rode (chain). It's almost as if anchoring is not part of cruising.
There is very volume at the pointy end. This suggests that the anchor shank should occupy this area... on the deck... with the windlass aft of that. The more aft the windlass is placed.. the more volume and drop for the rode exists. Of course for a small boat this volume eats into V berth (foot room). So I am thinking that a proper anchoring set up may require a minimum LOA so there is adequate volume/real estate. I must be lucky for the designer of the Contest36 got this right. However if I want to use an anchor with a longer shank than the one I use.... I have to move the bow roller forward.
Anchoring seems to be almost an after thought in many boats. But this one the architect cam up with a bizarre design in my opinion. It could work better with perhaps a different windlass.
pay attention... someone's life depends on it
SanderO is online now
post #3 of 8 Old 06-30-2019
krisscross's Avatar
Re: Windless Issues
You can disengage the clutch and pull the chain up by hand or release it. I do it all the time.
Plato
krisscross is offline
post #4 of 8 Old 06-30-2019
krisscross's Avatar
Re: Windless Issues
On mine, the clutch is disengaged by turning the central post counter clockwise with a winch handle.
Plato
post #5 of 8 Old 06-30-2019
colemj's Avatar
Re: Windless Issues
The windlass is mounted aft of the chain locker with a chain fall into it from what I see.
Those typically work in one of two ways. Some models work by just inserting a winch handle and cranking it in. Turning it one way loosens the clutch for free fall (and removes the cap if turned too much), but the other way tightens the clutch and pulls the chain in. Other models require an emergency kit where the cap and gypsy is removed, the emergency piece fit on the shaft, and a winch handle is used with the emergency kit.
Mark
SanderO likes this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #6 of 8 Old 07-02-2019 Thread Starter
davidpm's Avatar
Re: Windless Issues
Mark
That's what I thought.
I turned the cap until it came out and it did not seem to release the clutch.
Maybe this model requires the emergency kit.
davidpm is offline
post #7 of 8 Old 07-02-2019
S/V Caper Nonsuch 36
flyrod's Avatar
Re: Windless Issues
David, that looks like a Lewmar with several missing parts like like the stripper arm, cover, and lock out pawl, etc. To free fall, as described earlier, loosen slightly, the cones inside should slip, and the gypsy turn freely, reverse to manually hoist. Looks like lots of deferred maintenance there, perhaps the tapered cones are corroded together, use a bigger hammer next time.
flyrod is online now
The Following User Says Thank You to flyrod For This Useful Post:
davidpm (07-04-2019)
post #8 of 8 Old 07-04-2019 Thread Starter
davidpm's Avatar
Re: Windless Issues
This is a charter boat that I only infrequently sail so I'm not authorized to do any service on it.
Thanks for the info, I might pass it on but the guy gets cranky when I say anything about his boat.
davidpm is offline
