Stupid Anchor Light Question - SailNet Community
 30Likes
post #1 of 22 Old 07-16-2019 Thread Starter
Minnesail's Avatar
I’ve never anchored overnight my little boat before, and I don’t have a permanent anchor light.
I have one of these, and I thought I could run it up a stay with a spare halyard:
Portable LED Stern Navigation Light
It’s a 360ļ white light visible to 2 nm so I think that fulfills the the USCG requirements, right?
My next question is, would you want it pointing down or pointing up? If I just dangle it from the halyard it will point down, but I could attach its mounting pole which would weight it so that it would point up.
It’s probably a moot question, since I’ll likely add a permanent anchor light before I do any overnight anchoring (I’ve already run the wiring up the mast).
But I’m curious what people think.
Catalina 22
on a starboard tack
Minnesail is offline
post #2 of 22 Old 07-16-2019
bigdogandy's Avatar
Dock
Re: Stupid Anchor Light Question
Iíve used the same thing on occasion when my masthead light was on the fritz....just make sure you have batteries that will keep it on through the night!
Minnesail likes this.
Andy
Hard Aground
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
post #3 of 22 Old 07-16-2019
bigdogandy's Avatar
Dock
Andy
Hard Aground
1981 Endeavour 32
- Wendell Berry
post #4 of 22 Old 07-16-2019
Thats similar to the davis light.
Only negative is that it can be blocked by the mast...180 directly opposite
RegisteredUser is online now
post #5 of 22 Old 07-16-2019
Moderator
MarkofSeaLife's Avatar
Dock
I cant get the link to work in Europe
I had an emergency anchor light for a while of a LED in a coke bottle plugged into a cigarette lighter socket in the cockpit.
It worked fine till I could get a new one up the mast.
Note that the Colregs does not say it must be at mast top. It says that theres gotta be white light visible all round. think about it.
Then when you go permanent then, yes, the best place is mast top.
In ye old days it was a lantern swinging off some rope in the fore-triangle.
Mark
capta, CVAT and Minnesail like this.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #6 of 22 Old 07-16-2019
Learning the HARD way...
eherlihy's Avatar
I have an LED fixture that I haul up on the backstay so that I don't have to use the incandescent bulb at the top of the mast. I ALWAYS raise it so that it illuminates the deck/cockpit and so the other boobs on the water after dark can see that there is a boat under it.
Skipper Jer and Minnesail like this.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #7 of 22 Old 07-16-2019
Id go with 1/2 way up the backstay...and stick a couple solar landscape lites in winch sockets
post #8 of 22 Old 07-16-2019
Moderator
Dock
I had 6 all round the lifelines. They showed the shape of the boat close up. Not Colregs 2nms but they wernt anchor lights. I had one of those as well
RegisteredUser and Minnesail like this.
Sea Life
post #9 of 22 Old 07-16-2019 Thread Starter
Minnesail's Avatar
So we have one vote for pointing it down, so that it adds a little light to the boat for extra visibility.
I was fixated on it pointing up, because that's how anchor lights on the top of the mast are, but there doesn't really seem to be any reason for it.
The only downside I can think of with having the light point down is that if you're trying to enjoy some time in the cockpit staring at the stars you're going to have that anchor light glaring at you...
Catalina 22
on a starboard tack
post #10 of 22 Old 07-16-2019
Helps the drunks to see you in anchorage.
I find them very useful, also dirt cheap
And unfriendlies usually dont like lite
MarkofSeaLife, CVAT and Minnesail like this.
