Is Marine plywood a must? - Page 2 - SailNet Community
 35Likes
post #11 of 42 Old 07-26-2019
Degas's Avatar
Re: Is Marine plywood a must?
Marine plywood is intended to take a finish (varnish, paint), support structure, resist mold, and stay submerged. That means you pay extra for defect-free veneers of tropical hardwoods, no voids, more plies, and waterproof adhesive.
I'm guessing that there are fewer, less stringent requirements for holding batteries in a mostly dry, hidden corner of your boat.
SanderO and Zemurray like this.
I have a blog about sailing:
Degas is offline
post #12 of 42 Old 07-26-2019
overbored's Avatar
look for Baltic Birch plywood, made with water proof glue and several small plys of all birch. easy to work and finishes nice, many lumber yards will have it and some have smaller cut sheets.
Zemurray likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #13 of 42 Old 07-26-2019
outbound's Avatar
+1 for starboard. And it looks good once in with no additional coatings.
s/v Hippocampus
Outbound 46
outbound is online now
post #14 of 42 Old 07-26-2019
You can use Crezon. It's an exterior grade ply that they make highway signs out of. Affordable and should be a local good lumber yard.
They may call it MDO where you are.
Ninefingers is offline
post #15 of 42 Old 07-26-2019
Historical note: back in the 60's, the cost and construction of plywood sort of rose based on cost of glue and integrity of the layers.
Basic ply had voids and non-waterproof glue. A step up got you plugged (patches) on the voids. Next level was less voids and waterproof glue. The best product was better veneers with few plugs and waterproof glue, and was called "marine plywood". Cost more, but both the labor in added inspection of the veneers and cost of glue went up, too.
Sometime in the last 20 years (?) most plywood was laid up with waterproof glue, with the interior layers and their integrity adding or lowering the cost.
Then there are products that use just fibers and pieces of fiberous wood... and cost less.
Now we live in a world of "engineered" wood-derived products and prices range over quite a long scale, depending on required strength.
FWIW, if the wood in any project is just there for "coring", you can use less expansive ply and lay some glass and resin on both sides and encapsulate it.
Example --- for a couple of decades I have used honeycomb panels for all interior projects, joined with epoxy and glass where needed. (I salted away a quantity of this "scrap" paneling, in a lot of odd sizes, before the Boeing Surplus Store closed up. They used to dispose of it for fifty cents a pound..... Oh My.
Sure do miss that place!
1988 Olson 34, by Ericson Yachts.
Sail # 28400
Betamarine 25 (new 2018)
RCYC, Portland, Oregon
olson34 is online now
post #16 of 42 Old 07-26-2019
Senior Moment Member
SloopJonB's Avatar
No - for inside the boat top grade exterior fir ply works just fine.
Voidless marine ply is essential if you are building a hull or a dinghy etc but not for shelving, bulkheads etc. As noted, coat it with epoxy then paint.
I have rarely seen a production boat that used marine ply inside. In fact I've rarely seen it sealed with epoxy either, frequently left bare when it can't be seen.
Production boats are using variations of particle board now so anything is an improvement over that.
SloopJonB is online now
post #17 of 42 Old 07-26-2019
colemj's Avatar
Just to be clear, marine ply will delaminate, won't resist rot, and cannot be submerged unencapsulated. This is the same for Grade A exterior ply, which is also made with waterproof adhesives, is made to take a finish, and delaminates and rots at the same rate as marine ply if continually wet.
The important point between the two is that marine ply is generally made out of only one or two wood species (lots of finish veneer choices), while the construction choices of exterior ply is much larger.
As long as the wood is the same, the only difference between them are numbers of voids and plys. There is no magic around marine ply - it is just higher quality ply. Certainly useful in some applications, but not necessary in all applications.
Mark
chef2sail, TomMaine, Arcb and 1 others like this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #18 of 42 Old 07-27-2019 Thread Starter
Originally Posted by paulk View Post
If you think you can keep your plywood dry and want to use regular ply, it should work. The same reasoning goes for having a cored fiberglass hull. They never delaminate because of water infiltration. Boats are wet. Wet plywood delaminates. Marine plywood delaminates more slowly. If the shelf is simply for an additional battery, is plywood even required? Others have suggested using Starboard. Red cedar might be cheaper, is rot resistant and won't delaminate.
On another point - why are you putting heavy batteries in the lazarette? Running cables all the way back there adds to the weight too. Would a more central location shorten the wiring and improve the boat's balance?
Itís a small boat. The existing batteries, charger, and switch are located against the Cabin bulkhead, inside the lazerette/cockpit locker. Right next to the engine compartment. Short cables, just off to the port side of the engine. Itís a bit off center. The builder made fiberglass molded battery shelf/pockets for Group 24ís. I need to add a 3rd battery. Itís the only place to put it, right next to the others.
Zemurray is online now
post #19 of 42 Old 07-27-2019 Thread Starter
Lotís of knowledge shared on plywood. Really appreciate the feedback.
post #20 of 42 Old 07-27-2019
paulk's Avatar
The forward end of the cockpit locker is a much better location than the lazarette. Lazarettes are usually aft of the cockpit, up against the transom. That far aft would not be a good place for batteries.
paulk is online now
