bilge pump not working - Page 2 - SailNet Community
 3Likes
post #11 of 16 Old 07-30-2019
SanderO's Avatar
Re: bilge pump not working
my Rule automatic bilge pump stopped working. It had happened before. I decided to replace it.. and check the wiring... re route it when I did. I discovered the old pump worked.... so it's now a spare. This pumn deals with the water from the PSS dripless shaft seal... which is very very little water.
pay attention... someone's life depends on it
SanderO is online now
post #12 of 16 Old 07-30-2019
Originally Posted by SanderO View Post
.....This pumn deals with the water from the PSS dripless shaft seal... which is very very little water.
There should be zero water from a dripless. Itís in the name. 🙂
The only exception Iíve ever noticed is when first launched, but it stops that day. Not sure if something swells when wet or if itís just expansion and contraction in air.
Jeanneau 54DS
Minnewaska is offline
post #13 of 16 Old 07-30-2019
SanderO's Avatar
It drips once in a blue moon... but that small bilge catches some water that makes it way in from the cockpit. Very very little water. But the PSS does drip... just not when you are watching it!
Minnewaska likes this.
post #14 of 16 Old 08-09-2019 Thread Starter
sorry guys, original post had typos. it doesn't work on Auto, (nothing comes on when I fill up bilge with water), but on Manual I will hear it running, but nothing pumps out.
I guess I've got some sort of blockage? My understanding is that the float switch is an internal sensor or some sort with this model. I will take it apart and see. Hopefully that works
Vagab0nd is offline
post #15 of 16 Old 08-09-2019
Of the three wires on the pump ,one is neg 'return' one is hot when on manual and the other is hot when onauto. Even a good pump needs this apart from blockage or closed thruhull.
Capt Len is online now
post #16 of 16 Old 08-09-2019
PhilCarlson's Avatar
Dock
I had a what might have been a similar problem last spring: Pump ran but flow was almost non-existent. Something had taken up residence in the bilge line. Fed a bunch of bleach into the bilge with the pump trying to pump. Whatever it was went elsewhere. No problems since.
If your float switch doesn't activate the pump, but the pump runs in manual but doesn't drain, you could be dealing with two problems; line obstruction, and bad float switch/circuit (that you just hadn't noticed before).
PhilCarlson is online now
