Snake raw water intake hose through a tight area. - SailNet Community
 6Likes
post #1 of 17 Old 08-12-2019 Thread Starter
Hello,
I need to change my raw water intake hoses. I suspect they're 20+ years old and only luck is keeping them from bursting.
I'll have to snake one hose through some tight areas to get from the sea strainer to the water pump. Does anybody have advice on the best way to do this? Is there a good method of attaching the old hose to the new one and I just pull it through?
I was thinking to drill holes through the ends of both the new and old hoses (I would cut off the drilled portion of the new hose after it reaches its destination). I would sew them together with strong sail thread through the drilled holes. After that, I would strongly tape the hoses together. This might be enough for me to pull the hoses through the tight areas.
Is there a better way to do this?
The boat is a Pacific Seacraft 31
Thanks.
fune31 is offline
post #2 of 17 Old 08-12-2019
Re: Snake raw water intake hose through a tight area.
May help to leave new hose out in direct sunlight for a while
MarkofSeaLife likes this.
RegisteredUser is online now
post #3 of 17 Old 08-12-2019
Moderator
MarkofSeaLife's Avatar
Dock
I tape a mouse into the inside of the pipe to be removed, then pull out the old pipe and the run the mouse fall through the new pipe. This helps is go around some corners. I do it for my sanitation hoses.
But your way might work too.
Mark
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #4 of 17 Old 08-12-2019
When i changed long runs of water hose i just taped them.
It was a matter of pull, push, pull, push....lil bit at a time
post #5 of 17 Old 08-12-2019
pdqaltair's Avatar
A little KY can help too. Not joking.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #6 of 17 Old 08-12-2019
That and a heat gun will allow you to push on the larger hoses
post #7 of 17 Old 08-12-2019
chef2sail's Avatar
Teflon spray works for me
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #8 of 17 Old 08-12-2019 Thread Starter
Thank you for the replies.
Very useful.
fune31 is offline
post #9 of 17 Old 08-14-2019
All the above are great suggestions. I like the one with the string. In the past I would put the old and the new together with a barbed straight coupling and then tape over the joint. I have found with old water lines that were installed during construction that they are held in with plastic wire ties/ clamps so the tube doesn't slide through very easily.
justified is offline
post #10 of 17 Old 08-14-2019
One of None
deniseO30's Avatar
If the route for the hose is so long & twisty could it possibly be time to rethink the location of everything?
I've always been under the impression that a raw water intake, strainer and seawater valve should be pretty close to the engine.
SanderO likes this.
My last project!
deniseO30 is offline
