Restrainer for staysail forestay - SailNet Community
 4Likes
post #1 of 13 Old 08-15-2019 Thread Starter
My boat is a Pearson 367. Has a staysail. When not in use, that forestay is pulled back and restrained with a block system shown in the pic. But I am confused that the block system has so much line. Am I missing something? Why is the line so long? Or - no reason?
Any ideas?
Cheers - jballou
jballou is offline
post #2 of 13 Old 08-15-2019
chef2sail's Avatar
Re: Restrainer for staysail forestay
Any ideas?
Cheers - jballou
Does it have a cam cleat and can it be controlled from the cockpit?
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #3 of 13 Old 08-15-2019
Hes talking about when in use...not off to the side
..edit...
Is it actually a babystay
RegisteredUser is online now
post #4 of 13 Old 08-15-2019 Thread Starter
It does have a cam cleat. I don't think it can be controlled from the cockpit. And if I wanted to set it up, I would have to attach the stay to its contact point on the bow.
jballou is offline
post #5 of 13 Old 08-15-2019
Always learning...
Any ideas?
Cheers - jballou
That looks more like a tackle for a boom preventer system that someone started to use to restrain the baby stay. Our preventer tackle is nearly identical. The line length makes more sense in that usage, too.
Jonathan
S/V Pinniped
Jason 35
jwoytek is offline
post #6 of 13 Old 08-16-2019
Jonathan
That makes sense to me. But I'm curious how the stay is tensioned when attached to it's eye near bow? I see some toggles but not sure what i'm looking at.
s/v Miracle
PSC Flicka 20
Totuma is offline
post #7 of 13 Old 08-16-2019
Administrator
Jeff_H's Avatar
There were three rigs available on the Pearson 365, (sloop, cutter, and ketch). Only the cutter had a jibstay that was intended to fly a staysail. But that stay made tacking and jibing a pain in the butt so the jibstay was often set up to be removed when coastal cruising. Originally, there was a Highfield lever and turnbuckle. It looks like one of the owners switched to a block and tackle. While a block and tackle usually do not end up with enough tension, it allows the jibstay to be tensioned quickly with the staysail already attached.
My guess is that the extra line allows the tackle to remain attached to the chainplate while being pulled out of the way near the shrouds. This allows a quick and safer deployment.
It makes no sense that this tackle was meant as a boom vang or preventer.
jwoytek and capta like this.
Jeff_H is online now
post #8 of 13 Old 08-16-2019
Master Mariner
capta's Avatar
This is a common system, as Jeff said, and is available for exactly this purpose. It never was a boom vang or preventer.
Unfortunately, we cannot use it when we remove our staysail stay as we have a foil on it which won't make that bend.
jwoytek likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #9 of 13 Old 08-16-2019 Thread Starter
Yes - not able to control from the cockpit, and would not work with the stay attached to its chain plate as the stay is not long enough when the turnbuckles are loosed to max to be pulled out of the way
jballou is offline
post #10 of 13 Old 08-16-2019 Thread Starter
I'll take a pic next time I'm on the boat
jballou is offline
