Propane connections - SailNet Community
 8Likes
  • 1 Post By RegisteredUser
  • 1 Post By overbored
  • 2 Post By deniseO30
  • 1 Post By JimsCAL
  • 3 Post By capt jgwinks
post #1 of 9 Old 08-23-2019 Thread Starter
Scottrgrewe's Avatar
Propane connections
I have a small section of (brass?) Tube that is cracked. It's in a locker that probably had something heavy crashing into it. I want to replace it and protect it- but not sure what it is. Maybe someone can help. I bought a copper tube and compresion fittings, but nut doesn't fit.
Original equipment on a Dutch built contest 36. Top is what I bought and bottom is the cracked pipe that needs replaced
Scottrgrewe is offline
post #2 of 9 Old 08-23-2019
Re: Propane connections
May be a tapered fitting or differe t thread.
You could also have a section of hose made up to connect/bridge and run high away from anything that might go bump.
I would plan to do this one time, hoping to never have to worry about it again...for years.
SanderO likes this.
RegisteredUser is online now
post #3 of 9 Old 08-23-2019
SanderO's Avatar
I am thinking the problem is the difference between European sized pipe threads and what you bought in USA. This looks to be a flare fitting and the sleeve also seems wrong.
pay attention... someone's life depends on it
SanderO is online now
post #4 of 9 Old 08-23-2019
overbored's Avatar
looks like Din 2353 metric tube ferrule the one you bought is for copper but the old one is a ferrule and nut for steel tube fitting
SanderO likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #5 of 9 Old 08-23-2019
One of None
deniseO30's Avatar
PLEASE! do NOT use compression fittings for gas! The slightest vibration or movement makes the ferral swivel and leak! Please use Flare fittings or npt brass pipe & fittings. (Iron, galvanized iron, stainless pipe are ok too, except you have a marine environment)
OR! If you have a friend the hvac or plumbing business, they can get you special made convoluted stainless steel tubing & special fittings made for gas service, although it cost you more money. gastite and tracpipe are well-established manufacturers
https://youtu.be/DRCdi3bVFXU
SanderO and CVAT like this.
My last project!
deniseO30 is offline
post #6 of 9 Old 08-24-2019
JimsCAL's Avatar
Having multiple connections in the propane line between the tank and the stove is not a good idea. Best practice is to run a single section of hose or tubing.
Minnewaska likes this.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #7 of 9 Old 08-24-2019
This ^^
Jeanneau 54DS
Minnewaska is offline
post #8 of 9 Old 08-24-2019
SanderO's Avatar
I don't think this is an issue. The metal pipe I believe is connected to a shut off valve in the galley locker.
I recommend a solenoid with galley remote switch and replace hose and eliminate the in locker valve.
post #9 of 9 Old 08-24-2019
ABYC requires all connections except the final one at each appliance to be inside the propane tank locker. The standards are voluntary, follow them or not as you choose, but they are based on preventing practices that are known to cause problems.
Maine Sail, chef2sail and flyrod like this.
capt jgwinks is offline
