Hydraulic steering - SailNet Community
 5Likes
  • 1 Post By oldlaxer1
  • 2 Post By paulk
  • 1 Post By Arcb
  • 1 Post By SchockT
post #1 of 9 Old 08-29-2019 Thread Starter
davidpm's Avatar
Hydraulic steering
I'm working with a guy who just bought a big boat with Hydraulic steering.
It is almost 15 turns of the wheel from lock to lock.
This is a very big boat 60' about 55,000 lbs and the wheel is small.
Barn door rudder on a skeg.
The delivery captain complained that the number of turns made it hard to steer. I'm not surprised. I operated the wheel and it turns easy enough but of course, it still takes a while to do 15 turns. It is a bit of a workout.
I have him checking the model as some models have an adjustment for the number of turns. It will translate into a harder to turn the wheel if fewer turns used.
Does anyone have any experience similar to this?
davidpm is offline
post #2 of 9 Old 08-30-2019
oldlaxer1's Avatar
Re: Hydraulic steering
I sailed a few big boats with hydraulic steering and I would never own one, you get no tactile feedback from the helm. I don't recall the number of turns being an issue but I do recall how much I hated the steering.
davidpm likes this.
s/v Harmony
1973 Tartan 30 #186
Anchorage Marina, Baltimore MD
oldlaxer1 is offline
post #3 of 9 Old 08-30-2019
paulk's Avatar
Our launch drivers swear by these:
https://www.amazon.com/Stainless-Ste...58652775&psc=1
The autopilot probably doesn’t care.
davidpm and Hudsonian like this.
paulk is online now
post #4 of 9 Old 09-01-2019
SchockT's Avatar
I don't have any experience with boat hydraulic steering, but I suspect it is similar in function to hydraulic steering on old off road dump trucks I worked on years ago.
On those systems the wheel drive a hydraulic pump. If the seals in the pump were worn they did not move as much oil. Also if there is air in the hydraulics it wouldn't function very well.
It sounds to me like the hydraulic system needs an overhaul. I cant imagine 15 turns to full lock is normal.
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #5 of 9 Old 09-01-2019 Thread Starter
davidpm's Avatar
That sounds plausible. If the seals leak it will work but the pump will leak and not move as much oil.
It is supposed to have been serviced recently but in Guatemala.
I wonder if there is a way to test the seals without disassembling.
davidpm is offline
The Following User Says Thank You to davidpm For This Useful Post:
SchockT (09-02-2019)
post #6 of 9 Old 09-02-2019
Moderator
Arcb's Avatar
If the seals are shot, they will often leave an oily film on the ram and or around the pump.
tempest likes this.
Arcb is offline
post #7 of 9 Old 09-02-2019
SchockT's Avatar
Can the wheel continue to be turned if the rudder is held in place? That would be a good indication of leaking pump seals.
davidpm likes this.
post #8 of 9 Old 09-03-2019
bleed the system, see what you get
adki110 is offline
post #9 of 9 Old 09-04-2019
no steering turn like a car? lol
FeleciaRussell is offline
