Detachable windvane - SailNet Community
 3Likes
  • 1 Post By outbound
  • 1 Post By roverhi
  • 1 Post By hpeer
post #1 of 7 Old 3 Weeks Ago Thread Starter
Detachable windvane
I like the idea of a windvane but not having it permanently attached to the boat, are there any versions that are "easily" unmounted and mounted again when on passage?
Gary McKeown is offline
post #2 of 7 Old 3 Weeks Ago
Re: Detachable windvane
I think most can be set up that way by choosing the proper fasteners
RegisteredUser is online now
post #3 of 7 Old 3 Weeks Ago
bristol299bob's Avatar
I had this on a trailerable years ago. It pops on and off in a sec.
https://www.westmarine.com/buy/davis...96?recordNum=6
[EDIT] whoops, posting before coffee frequently problematic for me :-)
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is online now
post #4 of 7 Old 3 Weeks Ago
Old soul
MikeOReilly's Avatar
My I remove my Aries every season when I haul out. So it is removable. Not the easiest thing to do, but not too hard.
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
post #5 of 7 Old 3 Weeks Ago
outbound's Avatar
With my hydrovane I can easily remove windvane blade and the rudder. Except when on passage the windvane blade is below a settee cushion and the rudder fits into clever fittings on sugar scoop so both are out of the way. The tubings remain but are a convenient handhold getting in/out of the boat both from the water as well as a fixed pier.
Gary McKeown likes this.
s/v Hippocampus
Outbound 46
outbound is online now
post #6 of 7 Old 3 Weeks Ago
roverhi's Avatar
Are you asking about a wind sensor or a self steering vane. If it's the latter, the WindPilot Pacific vanes are held on by one or two bolts. Have to remove my WindPilot Pacific Light to meet the max boat length for the slip. Just pull the bolt and the vane is off.
The WindPilot Pacific Plus auxiliary rudder vane on my other boat has two bolts that hold it on. Because of the rudder it's more weight to handle but have pulled it by myself.
The mounting bracket(s) is still attached to the transom but that's a small bit of kit.
https://www.windpilot.com/n/wind/en/prod
roverhi is online now
post #7 of 7 Old 3 Weeks Ago
hpeer's Avatar
Aries lift up, itís out of production but they come up now and again. The mount remains but the servo and gearing comes right off.
Aries Lift Up Vane Gear Technical Illustration
I might be wrong but I donít think the new Aries has this feature.
33' Brewer, Murray 33, steel cutter
44' Pape, Steelmaid, cc steel cutter
hpeer is online now
Tags
auto pilot , self steering , windvane
