Prop strut caulking? - SailNet Community
 2Likes
post #1 of 11 Old 11-03-2019 Thread Starter
SchockT's Avatar
While my boat is out of the water for gelcoat and rigging repairs I have been painting the bottom and installing a new folding prop. While inspecting and cleaning my prop strut I noticed that where the strut meets the hull there was a flexible silicone-like caulking that was no longer adhered to the strut. I decided that I should peel it away and see what was underneath. From the looks of it the caulking was just fairing. It certainly wouldn't be sealing anything. Underneath the caulking is just gelcoat hull and resin filling the strut penetration.
On my last boat the strut just exited the fiberglass, with no caulking of any kind.
So once I remove the old material, what product should I replace it with? Should I use another flexible material like I took out, or should I fill the area and fair it with something harder? Perhaps an epoxy putty?
The first picture shows the old caulking, and the second picture shows what is underneath it. I was able to pull the caulking off with my fingers with little effort.
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #2 of 11 Old 11-04-2019
Re: Prop strut caulking?
If you're sure the strut is properly watertight on the inside, I'd use 4200 to fair it on the outside. If you peeled it off, with your finger, the surface probably wasn't well prepped. Be generous with the fairing. Most underwater parts call for 5200, which might be wiser. However, it's harder to replace and I don't think flexes quite as well.
Jeanneau 54DS
Minnewaska is offline
post #3 of 11 Old 11-04-2019
So, what is the purpose of the fairing, or caulking, or whatever?
Asking because I may be in the same situation; I have the same stuff at the strut, I think, but never had the guts to pull hard on it...
MastUndSchotbruch is online now
post #4 of 11 Old 11-04-2019
bigdogandy's Avatar
Location: Splitting time between Merritt Island, Fl and Asheville, NC for a bit
Dock
Iíve used epoxy fairing compound on that joint in the past on my boat. If I recall correctly Iíve had to rework it twice in the 11 years Iíve owned the boat....once in the initial haulout when I bought her and again about a year ago. A more flexible sealant like 4200 might work better?
Andy
Hard Aground
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
post #5 of 11 Old 11-04-2019
To avoid a leak, if the primary sealant were to crack or become otherwise compromised.
MastUndSchotbruch likes this.
Jeanneau 54DS
post #6 of 11 Old 11-04-2019
Thanks.
Hmm, given the state of the rubbery stuff on my boat, I guess the primary sealant is doing just fine
post #7 of 11 Old 11-05-2019 Thread Starter
SchockT's Avatar
Yeah it definitely was not intended as the primary sealant, it was intended to clean up the rough area around the penetration. After consulting with the guy at the boatyard who agreed with using 4200 I cleaned up the area, roughed up the smooth parts and filled the area with 4200. It's not perfectly fair, but it is better than it was.
post #8 of 11 Old 11-05-2019
What's the hole for in the strut? Zinc?
post #9 of 11 Old 11-05-2019 Thread Starter
SchockT's Avatar
Yes, I've never pot a zinc on my strut before, but this boat came with one so I might as well keep putting one on since the hole is there.
post #10 of 11 Old 11-05-2019
tx
