Barnacles on the prop and shaft - Page 2 - SailNet Community
 18Likes
post #11 of 30 Old 3 Weeks Ago
Re: Barnacles on the prop and shaft
When our boat is hauled there is usually at least some barnacles on the propeller. The power wash used up close takes most of it off, and wet sanding eliminates the bits that are left.
paulinnanaimo is online now
post #12 of 30 Old 3 Weeks Ago
overbored's Avatar
Originally Posted by Minnewaska View Post
This is the stuff you want. Take a putty knife to the big stuff. Personally, I don’t mind letting them die first. Fresh live barnacles spatter everywhere, when you scrape them off. Use a course scotchbrite, after spraying on the dissolver. Rubber gloves are a good idea.
Osborne's Barnacle Dissolver 16oz Spray https://www.amazon.com/dp/B0169AL3D2..._INGWDbJF5G7VN
we use clinging toilet bowl cleaner which is the same stuff at half the price. urea monohydrochloride
"GOLD RUSH" PRINDLE 16
overbored is online now
post #13 of 30 Old 3 Weeks Ago
Originally Posted by ReefMagnet View Post
.....coat with a poultice of flour and vinegar and cover with a plastic bag ....
Vinegar will eat away at the metal. I specifically use it to clean corrosion off metal. That would worry me, especially if on a folding or feathering prop.
Jeanneau 54DS
Minnewaska is offline
post #14 of 30 Old 3 Weeks Ago
Originally Posted by MastUndSchotbruch View Post
Hmm, the (3) reviews are not exactly gushing about the product
No accounting for Amazon reviews anymore. Vendors fluff their own stuff, competitors bash. It’s a polluted system, lots of documentaries on it. Not to mention the skill set of some users.
This is the product recommended and sold by PYI for the Max Prop. I’ve used it will great results.
I have no idea what’s in it, but I know there are acids that will quickly eat calcium before getting at any metal. I assume PYI would know the difference, but it is just an assumption. YMMV.
Jeanneau 54DS
post #15 of 30 Old 3 Weeks Ago
Good tip. I looked up the MSDS and see it has a few amines as well. No idea what they do.
I wonder, compared to vinegar, does it react more slowly with metal, or does it work so fast on the calcium you don’t need to leave it on long enough to worry about the metal.
Jeanneau 54DS
post #16 of 30 Old 3 Weeks Ago
CVAT's Avatar
Lets see, CH4N2O + HCL, can definitely see why it would work HCl is good at dissolving stuff.
Use your head for something other than a hat rest.
CVAT is online now
post #17 of 30 Old 3 Weeks Ago Thread Starter
mstern's Avatar
The things I learn on Sailnet.....
I'm putting rubber gloves on my spring commissioning list.
bigdogandy likes this.
mstern is online now
post #18 of 30 Old 3 Weeks Ago
bigdogandy's Avatar
Location: Splitting time between Merritt Island, Fl and Asheville, NC for a bit
Dock
There is no absolute need for harsh chemicals to remove barnies....this is what my prop looked like after letting it dry for a few days, scraping it with a painter’s 5 in 1, then hitting it with a wire brush in my drill and then an 80 grit flapper wheel. The epoxy barrier cost adheres very well to this surface.....
Andy
Hard Aground
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
post #19 of 30 Old 3 Weeks Ago
SanderO's Avatar
I get good results with an electric sander and never needed nor used a chemical. I usually only have a few of those critters when it's hauled out after a year
pay attention... someone's life depends on it
SanderO is online now
post #20 of 30 Old 3 Weeks Ago
Antifouling paint, even the expensive stuff designed for props, doesn't seem to adhere well to props. Using an epoxy primer or barrier coat first seems to help the paint adhere better. I prefer Sea Hawk's Tuff Stuff; it sticks to anything. Just don't put any paint or barrier coat under your zincs.
Damon Gannon is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
