CF Bowsprit - SailNet Community
 3Likes
post #1 of 17 Old 11-19-2019 Thread Starter
jppp's Avatar
CF Bowsprit
Wanted a sprit for the asym. Liked the selden one. loved the Trogear one. But $1700 not so much. Then I found this fitting on the inter-web which looks like it might be the forward end of the Trogear Sprit.
I purchased 2" CF Tubes on eBay. I'm about to form the attachment ends. I gotta plan for those. Might make one out of solid rod of delrin and use it to make a mold. Bought a yard of CF fabric.....
I purchased the "U" brackets to be attached to the anchor roller. Bought a solid rod of delrin to mill into the bushing for the forward fitting. Trogear uses titanium. If I can finish this for under $400 I'll be happy.
So far with the "U" brackets I'm in about $250.
I bought 3 of the forward fittings.... incase.
I'll post updates.
I had to sand the male ends of the forward fitting to fit the tubes. 'bout .5 mm. CF dust is bad news. I wore full face respirator and all the garb. I looked like Hans solo in Empire Strikes Back.
1985 C&C 35 MK 3 #150
LIS
jppp is online now
post #2 of 17 Old 11-19-2019
SchockT's Avatar
Re: CF Bowsprit
Looks cool! I assume you are running that with a bob stay?
Sent from my SM-G960W using Tapatalk
oysterman23 likes this.
2011 Jeanneau 39i Azura
SchockT is online now
post #3 of 17 Old 11-21-2019 Thread Starter
jppp's Avatar
Re: CF Bowsprit
Yes, with Adjustable bob stay. Following Trogear set up. Low friction eyes...
Just received the black 2' solid Delrin rod. Gunna put them on the lathe tomorrow.
LIS
jppp is online now
post #4 of 17 Old 11-27-2019
Re: CF Bowsprit
where did you find the fitting?
eowin is offline
post #5 of 17 Old 11-27-2019
paulk's Avatar
Re: CF Bowsprit
What kind of boat is this going on? I would be concerned about the anchor roller not being ready for this kind of loading, even with a bobstay.
paulk is online now
post #6 of 17 Old 11-29-2019 Thread Starter
jppp's Avatar
Re: CF Bowsprit
Fitting is from the manufacturer of the Trogear sprit in china. I bought three. if you want one it was $35 plus $20 for shipping. Or i'll make 2 more complete sprits or sell a kit. The parts are all out there. Mounting options are many. Length is what ever you want. As Paulk mentions, if you use the bow roller make sure it's sturdy enough. My bow roller is sturdy and I'm mounting near the stem. Farther out I would imagine increases loads. Remember the load comes from the halyard or tortion rope of a top down fuller. With the adjustable bob stay working against. The majority of the loads are compression with the bowsprit being pressed aft. I'm obviously no engineer. But I've seen one on TV.
oh, as to the make and model boat. C&C 35-3
LIS
jppp is online now
post #7 of 17 Old 11-29-2019 Thread Starter
jppp's Avatar
Re: CF Bowsprit
The mounting fittings.
The end pieces solid delrin. milled to fit CF tube and cut down. A hole will be drilled to fit mounting brackets.
https://www.facebook.com/photo.php?f...type=3&theater
LIS
jppp is online now
post #8 of 17 Old 11-29-2019
Sailnet Vendor
jblumhorst's Avatar
Location: San Francisco Bay area and West Coast by trailer
Dock
Re: CF Bowsprit
https://www.facebook.com/photo.php?f...type=3&theatere
I Cant open the links to see the photos. Error message says “Content not found. The link you followed may be broken, or the page may have been removed.“
Judy B
San Francisco Bay and Delta
F24 Trimaran
jblumhorst is offline
post #9 of 17 Old 11-29-2019
overbored's Avatar
Re: CF Bowsprit
The loads on the bowsprit are in compression when you tighten the halyard and bob stay to furl with a top down furler. the halyard needs to be tight but these loads are small in comparison to the side loads on the sprit when the sail is deployed and is on a close to beam reach. the sail at the tack pulls very hard to leeward and forward on the sprit. the bobstay takes the lifting load the sail puts on the bow of the boat but the sprit has to take the side and forward loads on the sprit. so the sprit has compression load on the leeward side of the sprit and a tension load on the windward side, trying to twist the bow roller off the boat
"GOLD RUSH" PRINDLE 16
overbored is online now
The Following User Says Thank You to overbored For This Useful Post:
jppp (11-30-2019)
post #10 of 17 Old 11-30-2019 Thread Starter
jppp's Avatar
The links are pics on the C&C owners group on Facebook. I’ll post the pics directly.
jblumhorst likes this.
LIS
jppp is online now
