sailcloth 3.8 vs 4.93 - advantages - SailNet Community
 6Likes
post #1 of 11 Old 11-30-2019 Thread Starter
rkinross's Avatar
I am considering buying new main and #4 jib for my 18 foot T-craft. The boat is sloop rigged with a swing keel. I sail on an inland lake north of Pittsburgh (Lake Authur) and sometimes trailer up to Erie. I have the choice of 3.8 or 4.93 sailcloth and both are the same price with Precision Sails. I am assuming 3.8 is a lighter material than 4.93. Precision Sails is recommending the 3.8 because they say it will set/trim better and is more appropriate for lake sailing. Are there any other factors I should consider in making the decision on what sailcloth to choose?
rkinross is offline
post #2 of 11 Old 11-30-2019
chef2sail's Avatar
Re: sailcloth 3.8 vs 4.93 - advantages
Maybe what type of sailcloth is available.
I would think the lightest sailcloth would be appropriate for the lake sailing as i assume they winds are light. Lake Erie I would think can give some pretty sporty winds. Also does this boat have main and jib?
Wind speed is one consideration, Air temp another. Cooler temp = heavier air. You have to figure out what wind range you will be doing most of your sailing in.
We have a larger 35 the main is 7.5 oz and the two jibs 155- 5.8 oz , 135- 6.8 oz.
Course on you smaller boat weight will make a big difference in the overall equation.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
The Following User Says Thank You to chef2sail For This Useful Post:
rkinross (11-30-2019)
post #3 of 11 Old 11-30-2019
Moderator
Arcb's Avatar
I think the problem with heavier sail cloth is that it takes more wind to fill and therefor doesn't sail as well in light air.
I would go with your sailmakers recomendation.
My 175 sq ft main on my 21 foot boat is still okay after 33 years, its about 3.8. A few patches, shape could be better, but not bad.
RegisteredUser likes this.
Arcb is offline
The Following User Says Thank You to Arcb For This Useful Post:
post #4 of 11 Old 12-02-2019
Sailnet Vendor
jblumhorst's Avatar
Location: San Francisco Bay area and West Coast by trailer
Dock
Challenge Newport 3.8 vs Challenge 4.93 High Modulus Low Aspect vs Challenge 4.93 Atlantic Low Aspect
I strongly recommend you choose the 4.93. It's a much superior cloth compared to the 3.8 for your 18 footer. The 4.93 is more tightly woven, requires less resin, and is made with lower stretch yarns. It has much lower stretch. (4.93 costs more than 3.8 too)
The 4.93 is excellent cloth for small boats, and will hold its shape longer than the 3.8. The 4.93 will be fine in light winds under 5 knots and better than 3.8 in enough wind to heel the boat or when reefed. (over 12 kts)
The 3.8 is an excellent choice for dinghies with bendy masts, IMO, and it comes in lots of colors. It's the cloth of choice for Optimists, etc. It's not a great choice for an 18 foot trailerable however.
The image below is a magnified picture I took of 4.93 on the left, and 3.8 on the right.
You can see how the 4.93 (on the left) has a much tighter weave and a much higher thread count than 3.8.
Judy B
San Francisco Bay and Delta
F24 Trimaran
jblumhorst is offline
The Following User Says Thank You to jblumhorst For This Useful Post:
rkinross (12-03-2019)
post #5 of 11 Old 12-02-2019
RichF28's Avatar
I don't know much about sail cloth, but I once lived in your area... Have you tried sailing on Pymatuning? I never had much luck on lake Arthur, too many hills blocking the wind.
RichF28 is online now
post #6 of 11 Old 12-02-2019
Sailnet Vendor
jblumhorst's Avatar
Dock
Something isn’t right worth this . 175 square feet of mainsail on a 21 foot boat makes no sense. That’s a bigger mainsail than you’d find on a much bigger boat, like a Catalina 27, that weighs around 7000 pounds.
Judy B
F24 Trimaran
post #7 of 11 Old 12-02-2019
Moderator
Arcb's Avatar
Yes, she moves in light air. Gets tricky to sail over 20 knots of wind speed
https://sailboatdata.com/sailboat/bay-hen-21
Arcb is offline
post #8 of 11 Old 12-02-2019
Sailnet Vendor
jblumhorst's Avatar
Dock
Now it makes more sense! A gaff rigged catboat.
Thanks!
Judy B
F24 Trimaran
post #9 of 11 Old 12-03-2019 Thread Starter
rkinross's Avatar
jblumehorst - Judy B - Thank you for your insight into fabric selection. I think I will choose the stronger 4.93 fabric for the reasons you have listed.
rkinross is offline
post #10 of 11 Old 12-03-2019 Thread Starter
rkinross's Avatar
Thank everyone for your replies to this post. I think I will choose the stronger 4.93 fabric for the reasons you have listed. There is not much information on the web when it comes to sail fabric.
rkinross is offline
Tags
3.8 , 4.93 , new sails , sailcloth , selection criteria
