Barnacle removal. - Page 2 - SailNet Community
 4Likes
post #11 of 15 Old 12-31-2019
krisscross's Avatar
Re: Barnacle removal.
Why would you have to clean even the ‘roots’ if you are going to paint? Just put the paint on. Paint will likely adhere better to the barnacle roots than pvc.
Plato
krisscross is offline
post #12 of 15 Old 01-01-2020
Senior Moment Member
SloopJonB's Avatar
I've never heard of putting bottom paint on an inflatable.
Pull it out of the water when you aren't using it.
SloopJonB is online now
post #13 of 15 Old 01-01-2020
outbound's Avatar
We use bottom specified for dinghies. Have hypalon. Before doing so had your problem. Bottom painting dinghies is worth it. Flipped dinghy over a left in the sun until real dry. Partially deflated tubes. Walked all over tubes then hit with a short length of pipe. Then scraped with stiff plastic scraper. Then carefully by hand with a scotchbrite. Then washed with fresh water hose and nylon scrub brush Got it down good enough without damaging tubes. Glass bottom just used a palm sander.
Advantage of letting the bottom go is you know exactly how high up to bring the bottom paint. Oh well...
Think being able to go on plane and having the dinghy expand and contract with temperatures changes decreases hard growth. Now have two 9 m seasons with current coatings.
SanderO likes this.
s/v Hippocampus
Outbound 46
outbound is online now
post #14 of 15 Old 01-02-2020
Cruiser
wrwakefield's Avatar
According to Carolyn at Boat Galley Liquid Barkeepers Friend [not the powder version...] works great and is safe on PVC, Hypalon, and fiberglass.
I have never tried it, but offer the qualified reference FYI.
Good luck! Bill
wrwakefield is offline
post #15 of 15 Old 01-04-2020
skipgundlach's Avatar
In addition to the bang/flex suggestions for removal, Barnacle Buster will work, albeit at much slower speeds than Muriatic acid.
Dirt cheep in the swimming pool department, and if you pour it into an epoxy mixing bucket/cup and use a cheapie chip or similar brush once you have the bodies mostly off, you can dab it onto the residue directly.
Use outdoors, gloves just in case (you should not be getting any on yourself if you are moderately careful), ditto eye protection, and rinse off occasionally to reapply if not fully dissolved critters.
After reaction with the calcium of the buggers it's just salt and water.
We don't keep the remainder of a gallon, as the stuff would NOT be good to leak into our bilge should the container leak, but at single-digit bux, it's great to use.
Be VERY careful in using any tool for removal; it's really easy to compromise the surface, leading to leaks.
As to prevention, we lift ours aside most of the time, but are in fecund waters a LOT so occasionally have to flip it and do the dance...
Morgan 461 #2
SV Flying Pig KI4MPC
See our galleries at
Follow us at
and/or
skipgundlach is online now
