Edson Rusted Idler Plate - Page 2 - SailNet Community
 4Likes
post #11 of 15 Old 01-08-2020
Re: Edson Rusted Idler Plate
Probably not know until you remove it. It may clean up just fine. If you have to make a new one at least you have an easy pattern.If you have to use headed bolts to hold the pulley brackets to the. plate some fender washers(spacers) on the long bolts could hold off the assembly from the glass 3/8 wouldn't change the angle
Capt Len is online now
post #12 of 15 Old 01-09-2020
Why not bronze plate ! 510 bronze .125 12x12 inch is $142 1/8th is $86 ! bronze nuts on the s.s. bolts no more worries ! Easy to work with ! @ On Line Metals ! Not affiliated ! Just checked on line ! If you go s.s. plate you have to stop the leakage to prevent crevice corrosion !
mike dryver is online now
post #13 of 15 Old 01-12-2020 Thread Starter
So, I pulled the plate & went at it with a hammer & a chisel.
Knocked a lot of rust out & there are a few new holes in the plate - but I think I got to it in time. The plate seems solid once I got the rust scale off.
I just ordered some ospho. Next week ospho treatment & 3 coats of rustoleum. Hope that does it.
DA119C4F-FCFC-4B74-A5A9-CBEA4A5E0C30_1578883093200.jpeg   90A4B6CF-82B1-41BA-A5B6-28520893DC96_1578883214081.jpeg
bristol299bob likes this.
hildamman is online now
post #14 of 15 Old 4 Weeks Ago
Kynntana (Freedom 38)
gamayun's Avatar
How easy was it to take off? I have to do mine too. Bought the new parts (backing plate, sheaves and chain) more than 4 years ago. Almost ready to get started on it in earnest now
gamayun is offline
post #15 of 15 Old 4 Weeks Ago Thread Starter
Not hard. All you will have to do is cut the old wire & undo 4 bolts.
