Edson Rusted Idler Plate - SailNet Community
 4Likes
post #1 of 15 Old 1 Week Ago Thread Starter
So, the Idler plates on my Edson steering pedestal are badly rusted (see the pictures). Edson replaced them with Aluminum ones in the early 2000's, but mine sadly predates that.
Edson wants $420 for a replacement and the cheapest ebay alternative is $300 + shipping (which is a steel one).
So, I am thinking of fabricating my own with G-10 sheets. The Sheaves are bronze and are in good shape, I could just cut them out of the rusted metal and screw them on to the G-10 sheets.
My questions are:
  1. What would be the minimum strength for the G-10 sheets? The thinner the better because of clearance issues, but obviously too thin will cause structural issues.
  2. Phenolic G-10 Sheets are much cheaper than Epoxy G-10 sheets, is there a difference in strength for my purpose?
hildamman is online now
post #2 of 15 Old 1 Week Ago
Re: Edson Rusted Idler Plate
Maybe my eyes are bad but those look like they can be cleaned up.
Regardless, a machine shop could make them in 316
chef2sail and PhilCarlson like this.
RegisteredUser is online now
post #3 of 15 Old 1 Week Ago Thread Starter
How would you clean it up? Towards the center, the rust has penetrated every layer of the backing plate. To me, this appears to be structurally compromised - or is there a way to fix this?
post #4 of 15 Old 1 Week Ago
Pull it from boat, remove rust..inspect well
Has to come out anyway
post #5 of 15 Old 1 Week Ago
hpeer's Avatar
316 or aluminum, pull it out and take it to a fabrication shop.
33' Brewer, Murray 33, steel cutter
44' Pape, Steelmaid, cc steel cutter
hpeer is online now
post #6 of 15 Old 1 Week Ago
SchockT's Avatar
Yeah looking at the pics the only holes I see look like they are supposed to be there. It looks like surface rust. I would pull it, sandblast or wire brush, inspect and prime and paint it if it checks out.
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #7 of 15 Old 1 Week Ago
Emmalina
Steve Bateman's Avatar
Looks to be about an hours work in the workshop with a good sheet of 316.
Steve Bateman is offline
post #8 of 15 Old 1 Week Ago
SchockT's Avatar
Assuming you have the right tools. Even so, you will notice the plate is not flat. There are raised channels to accommodate the bolt heads while allowing the plate to mount flush.
I'm not saying someone with mechanical skills can't fabricate a new one, just saying it may not be as simple as an hours work.
post #9 of 15 Old 1 Week Ago
overbored's Avatar
I would make it out if SS does not need to be 316, 304 would work. it does not need the channel or the curved slots. the plate is designed to be universal to fit any boat but once you know the mounting angle of the sheaves all that is needed is a tapped hole for the bolts so it becomes a plate with four mounting holes and four tapped holes for the sheave mounting bolts. could be through bolted if you make a clearance hole in the fiberglass under the plate
SchockT likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #10 of 15 Old 1 Week Ago Thread Starter
I was thinking of doing the same with G-10. With G10, all I would need is some brass bushings to secure the one end of sheaves to the G-10 plate and I could screw the the other end of the sheave directly into the G-10.
If G-10 can structurally deal with the load and deal with the moisture, then I am thinking, it might be the way to go.
