Which emergency use fibreglass matting should I have? - Page 2 - SailNet Community
 62Likes
post #11 of 54 Old 01-19-2020 Thread Starter
Moderator
MarkofSeaLife's Avatar
Dock
Re: Which emergency use fibreglass matting should I have?
Originally Posted by colemj View Post
You're not all of a sudden getting traditionally conservative are you? Next thing you are going to want a real "blue water boat"...
Mark
LOL exactly!!
Well, not really
Everything on the boat needs to have multiple functions or there is no space. This includes emergency equipment.
A bit of extra fibreglass could be used for a multiple of ideas. including to splint a fracture.
But the comments here have been very instructive. A sheet of 3-ply, a few screws, a bit of rubber etc is a good solution to the blown hatch thoughts.
Alsways good to have ideas.
Further, they are very cheap, already on board, multiple uses etc.
Fibreglass too is very cheap and doesn't take much space at all.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #12 of 54 Old 01-19-2020
overbored's Avatar
Flex tape. the stuff does work and sticks under water
MarkofSeaLife likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #13 of 54 Old 01-19-2020
Master Mariner
capta's Avatar
I think it will be quite difficult to get any sealer or epoxy to stick well to the topsides or bottom and a piece of plywood without grinding off the wax or antifouling paint. Think more toward a cover with a gasket and sealer than a patch job if you are offshore.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #14 of 54 Old 01-19-2020
Search underwater epoxy
Many choices
RegisteredUser is online now
post #15 of 54 Old 01-19-2020
Catalina 400 MKII
Scotty C-M's Avatar
I've read so many times that toilet bowl wax is a good emergency supply to keep on board. I carry two of them. Slather on a piece of plywood and screw it over the hole. I've never had to do it, but it sounds reasonable.
Scotty C-M is online now
post #16 of 54 Old 01-19-2020 Thread Starter
Moderator
Dock
Many choices
I have some. But this scenario is for a hole 1 or 2 feet wide x 1 foot long.
Sea Life
post #17 of 54 Old 01-19-2020
If it will adhere to a wet boat hull it should be good for your temp repair use with glass cloth/ply or most any thing
There are impressive tapes that would seal cloth, ply, most anything
post #18 of 54 Old 01-19-2020
A while back...
Overthehorizon posted about replacing bug screens with a poly or acrylic in their frames...when on passage.
To me, this makes good sense.
Initial impact
Think snubber
post #19 of 54 Old 01-19-2020
Mark,
Unsure if it answers all your questions, but few years back I read a short article on the subject in passagemaker dot com / channels / the ethos of damage control. Drill, screws, 1/4" plywood, 5200, putty epoxy, 100mph tape, felt or blanket, and expanding foam for support.
Biljrat is offline
post #20 of 54 Old 01-19-2020
Dirt Free
boatpoker's Avatar
His resin is epoxy. Mat will be difficult to work with because the binders don't dissolve in epoxy. It still wets out eventually with the binders intact, but it doesn't tool well. There are mats that can be used with epoxy, but if he wanted to carry glass on board, then maybe choose biaxial with a mat stitched on the back instead of roving and mat.
Quite correct, I missed the epoxy bit, cloth for epoxy.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
