Which emergency use fibreglass matting should I have? - Page 4 - SailNet Community
 62Likes
post #31 of 54 Old 01-20-2020
Re: Which emergency use fibreglass matting should I have?
All of our bunks have storage underneath, that can only be accessed by removing the mattresses. Some of it is critical enough or needed frequently enough, that I couldn't store plywood effectively and keep from going crazy.
Jeanneau 54DS
Minnewaska is offline
post #32 of 54 Old 01-20-2020
outbound's Avatar
Use the locker covers. All they are is painted plywood in all likelihood.
ThereYouAre likes this.
s/v Hippocampus
Outbound 46
outbound is online now
post #33 of 54 Old 01-20-2020
outbound's Avatar
Had opportunity to learn how to sail from a elderly librarian. She weighed less than a hundred pounds. A shock of silver hair and half moon readers on a string around her neck. She taught me more than all the professional captains, RYA certified sailors or others.
She taught me.
If itís hard you are doing it wrong.
If you didnít bring it with you you donít have it.
Donít look observe.
I did some nasty sailing with her on old boats as thatís all I could afford. It was amazing how she could think out side the box and jury rig. Think everyone here has the basic skills, supplies and intelligence to get themselves home. You guys are better sailors, well prepared, and intelligent. Especially you Mark. You have seen more weather, have more miles under your keel than I do. You have successfully sailed the sea of life and will continue to do so.
Donít worry, be happy.
BTW make sure your raft certification is up to date.😁
s/v Hippocampus
Outbound 46
post #34 of 54 Old 01-20-2020 Thread Starter
Moderator
MarkofSeaLife's Avatar
Dock
Patooui! P~
I read all those 1970s books where the dude is in the life-raft watching ships sail past.
So when my life raft inflates it's tied to the dinghy with its 18hp ob and plenty of fuel.
RegisteredUser likes this.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #35 of 54 Old 01-20-2020
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
This thread has focused on hull damage repair, but that was not what we used it for. We saved a cruise by repairing our leaking fuel tank in the Bahamas with epoxy putty, epoxy resin, and glass cloth. It worked although we replaced the tank a year later, and even then the repair was still sound.
The full story is in my wife's blog March 18, 2018.
Bill
wsmurdoch is online now
post #36 of 54 Old 01-20-2020
SanderO's Avatar
stick a drone in your ditch bag and you can fly it to a passing ship!
MarkofSeaLife likes this.
pay attention... someone's life depends on it
SanderO is online now
post #37 of 54 Old 01-20-2020
Originally Posted by Minnewaska View Post
....No idea how they managed to get the split.....
From what little i remember, they made a structual change to a tank in the bow..not underdtanding that its design was integrated to the hull
..and i could be all wet
Minnewaska likes this.
RegisteredUser is online now
post #38 of 54 Old 01-20-2020
outbound's Avatar
Have thought a lot about this since you first mentioned it.
Occasions boats gonna sink
Down flooding in a storm.
Collision breaching boat aft of water tight bulkhead.
Fire
Blown through hull I can’t cork for some reason.
Severe lightning strike causing catastrophic structural damage
Times I’m outside immediate help.
Passage outside helicopter range.
Foreign country with limited SAR capability
Severe weather making SAR impossible.
In all those situations powered dinghy will likely
Overturn due to severe weather conditions
Not have meaningful range if mid ocean
Burn before launch
I have davits but having had the decks awash from boarding seas and even been pooped in the past on other boats have seen davits mangled by waves, dinghy washed away if in davits or even from cradles on bigger boats. So I keep my dinghy deflated, turned upside down and very securely lashed to the foredeck on passage. I think unless you’re well over 50’ most cruisers do the same.
Hence I don’t see my dinghy as much of an option except in quite limited circumstances. I do see the raft as more viable even in coastal settings when the dinghy is in davits. Most successful rescues occur within the first day. Most are assisted by dsc vhf, epirb or flare. I practice raft/ditch bag/ deploy. It takes under 60 seconds even when I do it myself. This would allow me the time to work on saving the boat so question becomes moot. I think saving the boat is the best option. Particularly mid ocean and time and energy should be spent there rather than launching a dinghy. I have a efi engine at this time with it the available range it greater than with the prior 2 stroke. But still it’s meaningless in the settings where I would likely need self rescue. Unfortunately we depend upon others in most of these situations.
s/v Hippocampus
Outbound 46
post #39 of 54 Old 01-20-2020
Youre thinking only perilous conditions when failure happens
post #40 of 54 Old 01-20-2020
outbound's Avatar
Youíre right. But it my limited experience thatís when the fecal matter hits the rotating blade or when youíre exhausted and your mind isnít fully engaged.
s/v Hippocampus
Outbound 46
