Assistance w. 3D Modeling - Rudder Bushing - SailNet Community
post #1 of 3 Old 3 Weeks Ago Thread Starter
Hi all,
I am presently working on taking some of the vertical play out of my rudder on my Catalina 30.
In doing so I was considering having a custom teflon bushing made, trouble is I need a 3D model in order to receive a quote for same.
Anyone here who can assist with a very simple 3D model?
Thanks!
Frigast is offline
post #2 of 3 Old 3 Weeks Ago
overbored's Avatar
Re: Assistance w. 3D Modeling - Rudder Bushing
use the parts that Catalina makes for the replacement bushing. it is already engineered to do the job. teflon is a very soft material and does not make good rudder bushings, the material will flow under the movement of the rudder and could cause binding of the shaft. if the shaft is worn or scored on the bearing surface the teflon will be chewed up in no time.
If you want the ultimate in rudder bearings then Jefa is the way to go https://www.pyiinc.com/jefa-rudder/
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 3 Old 3 Weeks Ago
If you download Fusion360 you can model part fairly easily.
Sent from my Moto E (4) Plus using Tapatalk
skills4lou is offline
