governor and idle of a perkins 4-108 - SailNet Community
post #1 of 1 Old 2 Weeks Ago Thread Starter
The anti-stall device on my Perkins 4 108 was moved bleeding the bleeding Perkins 4-108. It ran great before the filter changes. it has been and bleed many times new starter new anti-stall assembly. weeks of trying and paying mechanics that scratch their heads. The engine will run well with the anti-stall device loose enough to drip fuel and turning the lock nut back and forth a little acts as a throttle? This is with the screw tried in every position up and down..? The 4 - 108 runs even better with the anti-stall device out and pouring out fuel like a bartender pouring a shot! Of course, this won't work. I do not know where to go from here with it? thanks if you can help?
Mike Kahuna is offline
