Bronze Engine Plugs: Ok to us Teflon tape? - SailNet Community
 1Likes
post #1 of 11 Old 02-06-2020 Thread Starter
I removed my hot water heater hoses and I am going to put bronze plugs where the hoses attached to the engine.
Is it ok to apply teflon tape to the bronze plugs' threads? I'm worried about the tape breaking off when I screw the plugs into engine. Is there a better product to use to seal the plugs?
Thanks.
fune31 is online now
post #2 of 11 Old 02-06-2020
cascoamarillo's Avatar
Re: Bronze Engine Plugs: Ok to us Teflon tape?
Sorry I don't have an answer to your question, but I'd like to subscribe to your post and see all the replies you may get. I am also thinking of removing those hoses engine-water heater, and the water heater too which I don't use.
I don't know if you can plug them, but I think I've seen some youtube video with a westerbeke engine (13-18?) out of the boat, running and has a small hose serving as a bypass for the in and out that are suppose to be connected to the water heater. Not sure this will help.
Best
cascoamarillo is offline
post #3 of 11 Old 02-06-2020
overbored's Avatar
it is ok to use the tape on coolant system just don't wrap the tape on the first thread then it will not be inside the engine. if in doubt use a thread sealer instead but still leave the first thread bare. tape is never recommended to be used in fuel systems. Tape can cause the fittings to become loose as the engine vibrates and the tape compresses.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #4 of 11 Old 02-07-2020
PhilCarlson's Avatar
Dock
A long time ago I did plumbing and heating. We only occasionally used teflon tape and usually not on a fitting that bore pressure, like showerheads. Teflon paste is by far superior. It's not that the tape might fail, it's that with paste, you never have the little gaps and wrinkles you get in tape that might allow a leak.
https://smile.amazon.com/Harvey-0230...1075600&sr=8-5
bristol299bob likes this.
PhilCarlson is offline
The Following User Says Thank You to PhilCarlson For This Useful Post:
fune31 (02-11-2020)
post #5 of 11 Old 02-07-2020
Master Mariner
capta's Avatar
Are you sure you want to add another dissimilar metal to your engine sea water cooling system?
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #6 of 11 Old 02-07-2020
Master Mariner
capta's Avatar
Actually, now that I think about it, our water heater was plumbed into the fresh water circulation hoses on the Perkins. Just needed to run the hose w/o the water heater in the line. I would guess the Westerbeke would be the same. If so, no plugs needed on the engine.
capta is online now
post #7 of 11 Old 02-07-2020 Thread Starter
Thank you for the replies.
I went with plumbers sealant today rather than the teflon tape. It worked very well.
post #8 of 11 Old 02-10-2020
Fune31, just a quick comment if I may.
A couple of years ago I was looking for bronze plugs and I could not find any supplier, anywhere.
Mostly they sold brass for bronze.
I am not sure where you got yours, but just make sure they are bronze.
The Westerbeke comments above are correct, there is a small hose from the outlet to the inlet port.
Lastly, there is no reason not to use a regular steel plug (better than brass), as the rest of the engine is all steel, and it does have a zinc in the system to protect its innards due to dissimilar metals.
SVTatia is offline
The Following User Says Thank You to SVTatia For This Useful Post:
fune31 (02-11-2020)
post #9 of 11 Old 02-11-2020 Thread Starter
SVTatia, thank you for your post.
I was able to get Bronze plugs at Fisheries Supplies and I used those. However, I originally ordered plugs from the local Yanmar dealer. I received steel plugs from them and they said that they would be fine. I was hesitant to use the steel plugs, though. So, I went with the bronze ones.
post #10 of 11 Old 02-11-2020
The point some were making was that a bronze plug on a steel part, in the presence of an electrolyte, will/could create galvanic corrosion. Steel would seem to be the better choice in this circumstance.
I’m also not sure, but saw mentioned that the hot water heating loop may be integral to the coolant circulation and couldn’t, therefore, be blocked. If that is the case, a jumper hose between the two previous barbs would be the solution to remove the heater.
Not saying you don’t have this, just adding to what’s already been said.
Jeanneau 54DS
Minnewaska is offline
