Pump repair - Page 2 - SailNet Community
 7Likes
post #11 of 35 Old 02-16-2020
Re: Pump repair
All good advice above. Personally, I’d start by trying to fill, redrill and tap. If that didn’t work, you can always over drill for one of the heli or time sert inserts.
I think I’m missing something tho. Jabsco still makes diaphragm bilge pumps. Is there something particularly unique here?
Jeanneau 54DS
Minnewaska is offline
post #12 of 35 Old 02-16-2020
SanderO's Avatar
Re: Pump repair
Large capacity bilge dewatering idea:
Does it make sense to consider several smaller capacity pumps? The can be located in different areas and likely one would do work unless there is a lot of dewatering to do. They can be plumbed with Ys to the discharge thru hull. One advantage is perhaps this would use fewer amps, be quieter and if one pump fails you still have the others working at dewatering.
pay attention... someone's life depends on it
SanderO is online now
post #13 of 35 Old 02-16-2020 Thread Starter
Master Mariner
capta's Avatar
Re: Pump repair
Originally Posted by hpeer View Post
It would annoy me to run around with a vital pump for which I could not get parts or replacements.
Yes, exactly, which is why I posted this. Thanks for the link. I do buy spares for this pump whenever they become available online. I will fix this problem, but was hoping for some input so I would have less experimenting to do.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #14 of 35 Old 02-16-2020 Thread Starter
Master Mariner
capta's Avatar
Re: Pump repair
I have one 6' deep bilge almost completely unreachable except by a pick up hose for this pump and the 2.5" manual's hose. No way I can see to use a centrifugal.
I have considered several smaller of the Par diaphragm pumps but unless this one fails completely, I'd rather not go through doubling or tripling the exhaust hoses which currently run from the pump out the transom (around 36 feet), adding a thruhull or two and the extra wiring.
capta is online now
post #15 of 35 Old 02-16-2020 Thread Starter
Master Mariner
capta's Avatar
Re: Pump repair
As above, this pump is out of production.
capta is online now
post #16 of 35 Old 02-16-2020
SanderO's Avatar
Re: Pump repair
What about using a 110v sump pump with a float switch?
I got one to use as a portable dink de watering pump because there a often times when I return to the boat after an absence and the dink is full of water... 8" deep! That's a lot. I plug the pump chord into shore power of my inverter... and it empties the dink lickity split. If it's really deep I hold the pump so it isn't completely submerged. It's a great portable dewatering pump...
these are like 55 GPM
https://www.lowes.com/pd/Zoeller-0-5...ump/1000675889
https://www.lowes.com/pd/Utilitech-0...ump/1000675931
post #17 of 35 Old 02-16-2020 Thread Starter
Master Mariner
capta's Avatar
Re: Pump repair
We carry 3, 110vac 1/2 hp, 1 1/4" discharge submersible pumps for emergencies (good for anchor/deck washing as well). They cannot get down into the deep bilge. If needed they would be placed on the lowest floor to maintain the water at that level until the emergency had passed, then either the 12 volt or manual pump would remove the rest of the water.
capta is online now
post #18 of 35 Old 02-16-2020
Re: Pump repair
Hey Capta ! Check with Captn Jim's up in Portland, Me. He has tonnes of equipment ! You would have to be persistent as he waits for customer to push a little ! 207-838-9902 ! No affiliation, just been there, seen all the equipment/parts etc he has ! He just came back from Mexico with a huge load !
capta likes this.
mike dryver is offline
post #19 of 35 Old 02-16-2020 Thread Starter
Master Mariner
capta's Avatar
Re: Pump repair
Thanks. Sent an mail.
capta is online now
post #20 of 35 Old 02-16-2020
T37Chef's Avatar
Re: Pump repair
Have you checked out GROCOs Paragon Junior? It may work for you...
Shawn
T37Chef is online now
