Aggressive non-skid and line wear - SailNet Community
 14Likes
post #1 of 31 Old 03-04-2020 Thread Starter
scratchee's Avatar
I'm planning to redo the non-skid on my coachtop and decks in the next month or two. Currently it's just a semi-flat paint over a bumpy pattern on the fiberglass, which seems to work fine. As an experiment, I did a hatch cover with Pettit EZDecks, and while the very rough surface seems like a good grip for bare feet, it also seems like it would quickly tear up my jib sheets and other lines that drag across it. Is this an issue with these aggressive textures, or am I over-thinking it? I also worry about kneeling on bare knees on those surfaces.
I guess an obvious related question would be if anyone has a favorite non-skid to recommend. I'm considering just using a flattened paint like Pettit EZPoxy (already used for everything else above the rubrail) over the existing textured non-skid areas. Context: budget minded, not a ton of time (or skill) on my hands, but willing to spend money on a decent and easy to use product that won't burn my lungs or give me cancer.
scratchee is online now
post #2 of 31 Old 03-04-2020
chef2sail's Avatar
Re: Aggressive non-skid and line wear
https://www.jamestowndistributors.co...SAAEgJTSPD_BwE
We used this 5 years ago.still going strong
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
The Following User Says Thank You to chef2sail For This Useful Post:
scratchee (03-06-2020)
post #3 of 31 Old 03-05-2020
Personally, I say the more grip the better. My factory non-skid is pretty aggressive and I like it. For sure, it's not comfortable to kneel on and shouldn't be, IMO. This may be a bit subjective, because any amount of kneeling, without kneepads, is now uncomfortable for me.
I wouldn't think your deck's non-skid would come in contact with a sheet or line under load, where chafe might become a problem. I don't think having the lazy sheets, for example, drag across the deck is an issue at all.
JMO
Jeanneau 54DS
Minnewaska is offline
post #4 of 31 Old 03-05-2020
SanderO's Avatar
OEM scored/pyramid pattern is not very good. And with lousy soles on your shoes it can be like an ice skating rink. Best footing is bare feet and I ALWAYS hold on to something... especially since my balance has been compromised.
I don't go forward much at all when the boat's heeled. I do to anchor/moor and tie to the fuel dock and the remove sail cover and put it on... and do do the cruising chute (rare).
Better non skid would be nice... but I can live without it given how I am using the boat and sailing.
pay attention... someone's life depends on it
SanderO is online now
post #5 of 31 Old 03-05-2020
Master Mariner
capta's Avatar
Over the years I've seen some pretty aggressive non-skid on boats and my first thought is how much damage would I do to myself if I fell on it.
Since I never (except if its cold) wear shoes or boots when onboard, it also looks very hard on the feet.
When I redid the decks on my 65' gaffer, I covered the fir decks with rolled on neoprene/hypalon (like on your inflatable but w/o the cloth) then covered crushed walnut shells with the last two layers. I used a flour sifter to insure there were no big pieces in the non-skid. The walnut shells are a preferred non-skid material because it won't absorb moisture and it can be easily sanded. This worked out to be a fantastic deck covering and non-skid. It was also a very good insulation barrier against the tropical heat and very easy to patch.
At the time, this was the method for ramps in high traffic areas like sports stadiums, etc. I don't know that the neoprene/hypalon would work very well on fiberglass, but the walnut shells (easily purchased) sprinkled in a boat paint could be superior to other products available, and much cheaper.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #6 of 31 Old 03-05-2020
google Rough Coat - a tan epoxy paint with grit already in it (or use ground walnut shell, available in different 'grits'
Paul Oman is offline
post #7 of 31 Old 03-05-2020
SchockT's Avatar
I can't see non skid coatings being a real issue on sheets, because they arent typically being dragged hard against the deck. Perhaps if you have a really aggressive coating on your deck and your sheets have a soft, loose jacket you might see a few pulls in the fibers of the jacket. (Kind of of like when cheap doublebraid dock lines snag splinters on a dock.)
As an old foredeck guy I believe working areas of the deck should have good grip. Certainly aggressive non skid can be hard on the knees, and on pants when sitting on the rail, but that the price you pay for being surefooted when it counts.
Personally I NEVER sail barefoot, except in dinghies of course. Good sailing shoes will give you better grip than bare feet AND protect your feet from stubbing on cleats and gouging on the edges of tracks. (Maybe it's because my feet are too soft?)
It is a personal preference, and maybe cruising is easier on bare feet than racing? There are entire threads dedicated to discussion about sailing shoes!
Sent from my SM-G960W using Tapatalk
SanderO and RegisteredUser like this.
2011 Jeanneau 39i Azura
SchockT is offline
post #8 of 31 Old 03-05-2020
I usually have fewer bruises and cuts coming back to the cockpit when wearing siped sandals.
RegisteredUser is online now
post #9 of 31 Old 03-05-2020
chef2sail's Avatar
The toes...the toes.....aren’t made to be broken.
Parkville, Maryland
Our blog-
post #10 of 31 Old 03-05-2020
Master Mariner
capta's Avatar
Originally Posted by SchockT View Post
Personally I NEVER sail barefoot, except in dinghies of course. Good sailing shoes will give you better grip than bare feet AND protect your feet from stubbing on cleats and gouging on the edges of tracks. Sent from my SM-G960W using Tapatalk
I've been sailing this boat offshore and inter island for around 10 years and if my situational awareness is so poor that I'm still stubbing my feet on cleats and gouging on them on the edges of tracks, I've probably got bigger problems than a pair of shoes will cure. lol
SanderO likes this.
capta is online now
