Cleaning algae off the hull - SailNet Community
 7Likes
post #1 of 16 Old 03-31-2020 Thread Starter
What’s the best way to clean algae off the hull of my boat?
Powerwash isn’t an option for me.
Pictures attached.
hildamman is offline
post #2 of 16 Old 03-31-2020
SchockT's Avatar
Re: Cleaning algae off the hull
Pictures attached.
Assuming that is gelcoat you can just use a green scrubbing pad. Looks like you are due for a good polish anyway
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #3 of 16 Old 03-31-2020
chef2sail's Avatar
Wiping with a green cloth...last use FSR....will also take most of the wax off
https://www.amazon.com/FSR-Davis-Fib.../dp/B0171Q13ZG
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #4 of 16 Old 03-31-2020
2 jars of elbow grease
capta and Whalerus like this.
jb cruzan is offline
post #5 of 16 Old 04-01-2020
Sailor
Gladrags1's Avatar
I would suggest using MEK and some scrubbing when necessary and avoid acid washes which end up making the gelcoat more porous. The stains occur because the algae gets into the pores and live there. Once you’ve removed the stains with MEK you can use a mild to medium grit polishing paste to close the pores even more. Then apply 3M’s Scotchguard Polish for year long protection and your stains will wipe off with a sponge. It worked for my 30 year boat.
olson34 likes this.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #6 of 16 Old 04-01-2020
colemj's Avatar
This: https://www.walmart.com/ip/MaryKate-...glass/33706365
Just brush it on and watch it disappear.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #7 of 16 Old 04-01-2020
Stiff brush and buckets of dish detergent soapy water. Then wash the soap off with clean water.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #8 of 16 Old 04-01-2020
You can buy oxalic acid crystals dirt cheap.
Mix in water
Wear gloves and watch magic occur
RegisteredUser is online now
post #9 of 16 Old 04-01-2020
colemj's Avatar
Oxalic acid will remove the stain very well, but won't remove the algae itself. The On/Off I linked to contains hydrochloric and phosphoric acid, which will dissolve and remove the algae.
No need for elbow grease or scrubbing. It will remove wax, but that isn't a concern by the time the hull looks like that picture.
Mark
sailingfool and capta like this.
- Current boat
- Previous boat
colemj is offline
post #10 of 16 Old 04-01-2020
Master Mariner
capta's Avatar
The green 3-M pads are like sandpaper. I wouldn't suggest using those on your hull. The On&OFF will do the job for the most part, but since it is a combination of a couple of pretty corrosive acids, use EYE protection as well as gloves.
Otherwise, a good brush and soapy water will certainly do the trick with those jars of elbow grease mentioned above. This actually might be the best option if you are in lockdown as most of us are, and could use the exercise. lol
olson34 likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
