"Marine" GFCI Outlet? - Page 6 - SailNet Community
 2Likes
post #51 of 83 Old 03-02-2011
Originally Posted by eherlihy View Post
... and yes I AM certifiable! - Just ask my wife.
No need...I've met you... and it was self evident...
sailingdog is offline
post #52 of 83 Old 03-02-2011
blt2ski's Avatar
I'm helpless according to my wife......or was it hopeless....
anyway, nice to know the modified sine inverter "could" be the issue for the one a page or two back blowing the gfci's. I was wondering if the spike, low pike low...... of the inverter might cause an issue.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is online now
post #53 of 83 Old 03-02-2011
Originally Posted by RhythmDoctor View Post
I'm working on a netbook-based chartplotter system for fair-weather use at the helm (described on another thread), but unfortunately the netbook runs off of 18-19v, so a simple 12v adapter will not work. Since you seem knowledgeable, maybe you can answer a lingering question about this. I have a real nice Compaq car adapter that puts out 90w @ 19v and is plug compatible with the Netbook, but the Netbook actually only needs about 19w to run. Do you happen to know whether a less oversized charger would be more efficient, or do these adapters draw only as much power as needed to drive the computer? I'd like to know whether to just go with what I have, or look for a lower amperage adapter that puts out 18-19 volts.
I like to think I'm knowledgeable, since I have a degree in electrical and computer engineering As others have said, if the netbook only draws 19W, it won't use the full 90W the adapter is capable of sourcing. But, the efficiency is not constant, it's a curve that varies with load. On most switching regulators, which this adapter almost certainly is (and inverters are a type of switching regulator, so it applies to them too), they are very inefficient at near 0 draw and near their maximum draw, with peak efficiency somewhere in the middle. Peak efficiency on a switching regulator can be 90% or perhaps even better. For your purposes, I'd say just go with the adapter you have, getting another one isn't going to save you much power.
1979 Gulfstar 37 Laissez Faire
rmeador is offline
post #54 of 83 Old 04-09-2011
mitiempo's Avatar
I know this thread is a bit stale but I came across the list of Xantrex approved GFCI's.
From the Xantrex XM1800 manual:
Brian
mitiempo is offline
post #55 of 83 Old 04-09-2011
Learning the HARD way...
eherlihy's Avatar
BOTH Leviton models above are obsolete and have been discontinued.
The Hubbell GFR5252 is still available for ~$25
eherlihy is online now
post #56 of 83 Old 04-09-2011
mitiempo's Avatar
Good to know.
Brian
mitiempo is offline
post #57 of 83 Old 03-20-2012
Re: "Marine" GFCI Outlet?
It is my understanding that there is a big difference. Household GFCI's are not ignition protected meaning it were to trip it could cause a spark.
reinell190 is offline
post #58 of 83 Old 03-20-2012
Leviton: Cheapest possible product, zero customer support. On my list of vendors to be avoided at all costs.
hellosailor is offline
post #59 of 83 Old 12-22-2015
Originally Posted by SEMIJim View Post
During the survey, our surveyor noted Abracadabra's AC outlets in the galley and on one of the bulkheads separating the main cabin from the head had no GFCI protection. Naturally, he recommended adding GFCI protection, and advised that we needed a marine GFCI outlet, not just the average GFCI outlet you'd pick up at Home Depot, or whatever.
So how do you identify these and where do you get them? Saw a GFCI outlet at WM, but the labeling was scant (looked like perhaps it'd been re-packaged?) and said nothing about "marine" on it. (It certainly had a "marine" price on it, tho .)
These outlets are the "modern"-looking, rectangular kind.
Thanks,
Jim
We have a 1982 Tollycraft Yacht and cannot locate the GFCI, where would it be located? Thank you. Bob
bob2 is offline
post #60 of 83 Old 12-22-2015
bob2 is offline
Adding GFCI Outlet: Looking for Surface mounted back box ns22simple Electrical Systems 1 06-10-2013 06:24 PM
Is ELCI needed if AC only runs to GFCI outlets? eko_eko Electrical Systems 5 11-17-2012 10:42 PM
Water heater popping GFCI jetdrvr393 Gear & Maintenance 5 09-06-2011 04:57 PM
GFCI Outlets brokesailor Gear & Maintenance 2 04-09-2011 05:52 PM
GFCI / Galvanic Isolator Problem thekeip Gear & Maintenance 10 01-09-2008 07:57 PM
