Looking for advice from dodger owners - Page 3 - SailNet Community
post #21 of 39 Old 06-05-2008
brak-
posted a link to a photo of thaty track over on sailrite's site in post #7.
btw, sailrite calls it awning track
sailingdog is offline
post #22 of 39 Old 06-05-2008 Thread Starter
Sea Slacker
brak-
the link was broken, but I just found it based on the name - thanks!
thats one reason its tough to find things - I never know what the accepted name is and keep searching for thingamadoo.
brak is offline
post #23 of 39 Old 06-05-2008 Thread Starter
Sea Slacker
To clarify - the guy that I am looking to hire to do the work is doing excellent work locally (he very well may be the best). The problem is - my boat is "special" and defies usual installation practices. So, this is where the issue is.
BTW, awning track probably won't work in this case because it has to be attached with provided 1/2" screws and the top thickness is less than 1/8".
brak is offline
post #24 of 39 Old 06-05-2008
Super Moderator
Maine Sail's Avatar
Like this..
Originally Posted by Freesail99 View Post
How does a dodger not interfere with a cabin top traveler ?
Like this...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #25 of 39 Old 06-05-2008
Super Moderator
Maine Sail's Avatar
brak-
You mean this stuff that I posted earlier?
BTW Seth (the high end canvas guy I do some consulting work for) prefers to use the plastic awning track vs. the aluminum.
It bends with a heat gun and you don't damage the anodizing which leads to premature oxidation of the aluminum when you bend it. Bending anodized aluminum awning track can lead to premature anodizing failures..
He has a fair number of his dodgers that have done full circumnavigations every one using the plastic "awning track" or "luff strip" as he calls it.....
There are different types of awning track and they do not have to be installed using screws. On aluminum frame windows Seth will sometimes use aluminim pop rivets or monel pop rivets
One other style:
And a link to other styles:
Google Image Result for http://www.barbourcorp.com/images/images-marine/R1445-small.gif
______
post #26 of 39 Old 06-05-2008
JohnRPollard's Avatar
Halekai,
What is the normal method for attaching that plastic track to the coachroof/deck around the companionway seahood? Does it get screwed down, or is an adhesive used?
JohnRPollard is offline
post #27 of 39 Old 06-05-2008
I'd agree that the plastic track is probably better than the aluminum track since it can be bent to fit odd curves more easily than the aluminum.
JRP—
It is normally attached via screws, and bedded as any other deck hardware would be.
post #28 of 39 Old 06-05-2008
Super Moderator
Maine Sail's Avatar
Originally Posted by JohnRPollard View Post
Halekai,
Seth will drill, countersink, bed with Sikaflex 291 or 3M 4200 and then screw the into place. It's usually one fastener about every 4-6" depending upon the use the boat is intended to see.
The track can also do a nice job of hiding previous holes from poorly constructed dodgers plus it's totally hidden by a lapel under the dodger and you never see it nor is it exposed to UV. No visible fasteners is a big plus too.
The best part is you don't get or see fastener creases in your windows because the load is distributed evenly across the entire leading edge of the dodger and you are left with smooth crease free windows.
I've taken some big green water off my Mobile Marine Canvas Dodgers and never had one fail using the awning track...
______
post #29 of 39 Old 06-05-2008
This isn't exactly on topic but....
On my last dodger there were little covers that snapped over the windows that we would remove when sailing.
This last time I decided to eliminate them and have the canvas guy make a cover for the entire dodger. It's easier to deal with than all the individual covers and it protects the cloth as well as the windows. I know thats not what you were talking about but I thought it was a good idea and have been happy with it.
Steve
Attachment 1728
knothead is offline
post #30 of 39 Old 06-06-2008
Glad you're keeping the windscreen. I've looked into fabricating a hardtop for my Rasmus, but I'm pretty happy with the soft top.
If you have to repower in the next few years (or weeks, you never know) the soft top pops off easily for engine haul out.
I've seen a picture on yachtworld of a Rasmus in Annapolis maybe; it has a hard dodger that stands independent of the windscreen. Looks functional.
Rorke
Rorke is offline
Looking for hard dodger top DIY ideas... Faster Gear & Maintenance 42 05-07-2017 10:04 PM
Looking at a 31 this week. Any advice from owners? RatHatDiver C310 3 12-29-2014 11:49 PM
To Dodger or not to dodger bdd6 Gear & Maintenance 48 09-07-2011 12:45 PM
hard dodger vs soft dodger bluetommy77 Boat Review and Purchase Forum 6 10-07-2007 06:29 PM
How many Atomic 4 owners or former owners do we have ? NewsReader Mass Bay Sailors 0 04-26-2007 10:15 AM
