Low buck projects- Let's see 'em! - Page 131 - SailNet Community
 1315Likes
post #1301 of 1600 Old 02-01-2015
Back to just the Jon boat
therapy23's Avatar
Re: Low buck projects- Let's see 'em!
Thanks PorFin and Sloop.
My steady hand on chisel sharpening leaves me with a nice curved edge. Would probably need to take a lot of metal off to fix.
therapy23 is offline
post #1302 of 1600 Old 02-01-2015
Originally Posted by therapy23 View Post
To further the drift....................
Please forgive my ignorance but please explain glass with 6 sides, where to get that "real" wet-dry sandpaper and how to sharpen a chisel properly.
Thanks.
Google "Scary Sharp" -- that's the slang term for sharpening with sandpaper. There's a bunch of videos and stuff out there.
Get the sandpaper at an auto parts place. (Or a marine supplier, to get this back to nautical talk)
I use a jig to keep the angles right.
gptyk is offline
post #1303 of 1600 Old 02-02-2015
One of None
deniseO30's Avatar
this is the last of the scrap from my bench build. 23" X 11" for a possible kitchen cart/island or on the boat.
This took too long to make! Now my scary sharp tools are dull again. Beech is hard!
My last project!
deniseO30 is offline
post #1304 of 1600 Old 02-02-2015
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
my new exhaust mixer is a cross between this
Yanmar 2QM20 mixing elbow - SailboatOwners.com
http://forums.hunter.sailboatowners....0&d=1382657476
and this
Moyer Marine Atomic 4 Community - Home of the Afourians - View Single Post - Where did you get 1-1/4" black iron pipe and fittings?
I will post pictures when done
cost about $20 in fittings and $25 to machine shop for turning and cutting thread on a pipe coupling
deniseO30 likes this.
Bill-Rangatira is offline
post #1305 of 1600 Old 02-21-2015
aka $tingy Sailor
This Old Sailboat's Avatar
Sitting by the fire this winter, I thought I'd try my hand at coachwhipping my tiller handle similar to the cover of Don Casey's book 100 Fast and Easy Boat Improvements, which I read and reviewed on my blog.
I had to devise a way to accommodate the taper in the handle, but it turned out great and only cost me $4.29. For the back story, instructions, and tips, see How to add coachwhipping to your tiller handle on my blog.
fryewe, deniseO30, Bene505 and 5 others like this.
Explore over 100 DIY sailboat restoration and improvement projects at
This Old Sailboat is offline
post #1306 of 1600 Old 02-21-2015
Skipper Jer's Avatar
Very nice whipped tiller.
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
post #1307 of 1600 Old 02-22-2015
One of None
deniseO30's Avatar
Woo.. not really low buck project but it works! It's Singer industrial 241-11 It rocks! plugged it in and this old motor starts a flywheel a spinning... the treadle controls the speed, takes a bit getting the right touch to get low speed.
My last project!
post #1308 of 1600 Old 02-23-2015
Dave_E's Avatar
I hope I'm not the only dummy who just lived with a boom that would waggle back and
forth when you motor along, or sit at moorage (slip). I used to pull the main sheet in "real tight"
and the boom vang. I've seen little wire clips that some use to clip the boom end to the backstay
(I don't think they really work well). So I came up with this last summer while motoring to Victoria BC
(beautifull city). Cost = practicaly nothing. Result = 100% practical. If you don't have a doger with hand holds you can just string a line anywhere... main sheet holds it off to one side a little and the other line pulls on the boom the oposit way, resulting in a boom that has no more waggle.
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #1309 of 1600 Old 02-23-2015
We often tie the boom off to one side, usually with the tail of the mainsheet, in a rolly anchorage to avoid that and the noise of that wee bit of motion..
I hope your dodger frame is skookum enough to take the loading.. I'd prefer to tie that off to a toerail or a outboard cleat...
Faster is offline
post #1310 of 1600 Old 02-23-2015
Barquito
Barquito's Avatar
Denise, that sewing machine is awesome. I bet you could stitch plate steel together!
Valiant 32
Barquito is online now
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
Low-Buck Dinghies- Lets See 'em! bljones Gear & Maintenance 48 05-09-2013 05:30 PM
Lazy Jacks: Lov'em or Leave'em? Winderlust Sailnet.com Polls 44 04-02-2013 03:46 AM
