Low buck projects- Let's see 'em! - Page 141 - SailNet Community
 1315Likes
post #1401 of 1600 Old 06-26-2015
Freedom isn't free
Dock
Re: Low buck projects- Let's see 'em!
Sure what do you wanna know?
drawing internally
and
Freedom, a 1983 C&C 32 sailing Smith Mountain Lake, VA
SHNOOL is offline
post #1402 of 1600 Old 06-27-2015
Originally Posted by CharlzO View Post
That looks great, and definitely a creative solution that allows for future access.
Thanks. I was also thinking the wood strip would also make a good attachment place to mount a fan by the galley. But, that's another project.
Mike
Currently: Hunkering down for a bit.
mbianka is online now
post #1403 of 1600 Old 06-27-2015
Got rid of the useless hideous looking icebox in my Mirage. All wood was scrap and hardware cost around 10$. Was planning on building a custom cooler attached to it but I like the easy access to the bilge. Interior ledge in door is keeping wiring off the bottom too.
Tubesteak is offline
post #1404 of 1600 Old 06-27-2015
utchuckd's Avatar
Originally Posted by mbianka View Post
A couple of years ago to make the removal and re-bedding of my boats handrails easier. I enlarged the area under the cabin top to gain access to the mounting screws. This left some unsightly rectangular openings in the liner. This spring I finally got around to cover those spots up using some molding from the Home Depot:
THE BIANKA LOG BLOG: FIXING A HOLE: HEADLINERS AND HANDRAILS
Is the molding just screwed into the cabin top?
Donnie Harris
1980 O'Day 23
utchuckd is offline
post #1405 of 1600 Old 06-28-2015
Actually it is just screwed into the liner. There is a little space between the liner and the actual cabin top. If my boat did not have this liner I would have had easier access to the screws holding the handrails.
utchuckd likes this.
Mike
post #1406 of 1600 Old 06-28-2015
TakeFive's Avatar
This low-bucks project is not complete yet, but I thought I'd share it with you to get your comments before I finish.
Since I have started anchoring a little more frequently, and am aways dealing with heavily caked-on mud even on a small lunch hook, I would like a washdown system. However, I always try to keep things simple and portable on my little 25 foot boat, and I really don't want to create another through-hull penetration. So I decided to make a portable wash-down system.
I found this portable submersible pump on Amazon:
http://www.amazon.com/gp/product/B00F2LANF4
It is designed to be lowered through the bunghole of a drum and run from a wired remote switch while hanging freely. It pumps non-flammable solvents (diesel, etc.), but also water. The specs indicate that it should have enough head to drive a spray nozzle, and my freeboard is about the height of a typical drum. So I think this has a chance of being a nice little portable washdown system once fitted with a hose and nozzle. For $20 I decided it was worth a try, so I bought one.
Out-of-the box, it comes with battery clips to attach to the lead posts on a battery. My initial dry test indicates that it draws only 1 amp, though I expect that amperage may increase under the load of pumping water (will test as soon as I can). But I think that it is low enough current that I will be able to cut off the clips and attach a 12v plug. I have 12v sockets at various locations on my boat, so I should be able to easily plug it in when I want to use it.
I want to cut off a relatively short (~8') length of garden hose. The hose barb is 3/4", but most of my hoses are 5/8" ID, so I need to figure that out.
Of course, this system could also be a backup bilge pump in case of emergency. I'm debating whether to cut the hose long enough to go all the way out the companionway hatch and over the gunwale, or whether I just figure a way to attach the hose to drain into the galley sink if it was pressed into use as an emergency bilge pump.
Any suggestions?
Bill-Rangatira and Northeric like this.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall, MD
TakeFive is offline
post #1407 of 1600 Old 06-28-2015
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
used track lights $25 for 6
came with new halogen bulbs which are $20 for 6
bases for surface mounting $5
new 12v sockets $5 ea.
12v led spot bulbs with mr16 ends $7 ea.
cost per light was $21 or less if you count the free light they came with
Bill-Rangatira is offline
post #1408 of 1600 Old 07-05-2015
TakeFive's Avatar
...Since I have started anchoring a little more frequently, and am aways dealing with heavily caked-on mud even on a small lunch hook, I would like a washdown system. However, I always try to keep things simple and portable on my little 25 foot boat, and I really don't want to create another through-hull penetration. So I decided to make a portable wash-down system.
Amazon.com: Docooler 12V Water Oil Diesel Fuel Transfer Pump Submersible On/Off Switch Car Van Stainless Steel: Home Improvement
Of course, this system could also be a backup bilge pump in case of emergency...
Project complete. Total cost about $43:
SHNOOL and Group9 like this.
TakeFive is offline
post #1409 of 1600 Old 07-05-2015
Back to just the Jon boat
therapy23's Avatar
Cool.
What sort of stream do you get from it?
therapy23 is offline
post #1410 of 1600 Old 07-05-2015
TakeFive's Avatar
Originally Posted by therapy23 View Post
Cool.
I am not sure I have the words to answer that. My video may be the best answer you can get to that question.
TakeFive is offline
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
Low-Buck Dinghies- Lets See 'em! bljones Gear & Maintenance 48 05-09-2013 04:30 PM
Lazy Jacks: Lov'em or Leave'em? Winderlust Sailnet.com Polls 44 04-02-2013 02:46 AM
