Low buck projects- Let's see 'em! - Page 144 - SailNet Community
 1315Likes
post #1431 of 1600 Old 09-23-2015
svsolaris's Avatar
Re: Low buck projects- Let's see 'em!
Hi,
I have a quick one that isn't perfectly finished yet. The head on my boat is at the end of the bed. Too close for comfort! So I made a simple box to cover it that also doubles as a bed extension. It works really well. I just need to have a proper pillow made for it. It cost as much as 1 piece of 48x48 ply wood does at Home Depot. Now that it worked so well I might redo it next summer with a nice piece of wood.
Jay
svsolaris is offline
post #1432 of 1600 Old 09-23-2015
fryewe's Avatar
Originally Posted by svsolaris View Post
Hi,
Jay
Nice, Jay.
You could get rid of the drop board channels and the hassle of dealing with the drop board after you pull it out by putting a piano hinge on the front of the cover and attaching the drop board to the other side of the hinge. Then the front and top would fold up and back as one piece. A barrel bolt could fix the assembly in position when either raised and lowered.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
post #1433 of 1600 Old 09-23-2015
SVGimmeShelter's Avatar
Originally Posted by johnshasteen View Post
Cheap storage for those small propane bottles that you don't know how to store. I went to Home Depot and bought a three-foot piece of #10 PVC pipe the right diameter to hold the bottles, a glue on (I know it's called weld) bottom cap and an adapter and screw on top. Put it all together, drilled several holes in the bottom and attached the rig to one of the slanted legs of the stern pulpit with a couple of hose clamps. It's lasted for about 10-years now and shows no sign of wear.
Oh my gosh, this is genius. Guess my husband has a project for the weekend.
SVGimmeShelter is offline
post #1434 of 1600 Old 09-23-2015
svsolaris's Avatar
That's an interesting idea! That would look really sharp.
Thanks!
post #1435 of 1600 Old 09-23-2015
Originally Posted by piav View Post
I'm going all LED inside...would love to hear how you make your own lights!
Running the risk of looking like I'm plugging my blog, but this does actually provide a good explanation, and with pictures.
Repairing a cabin dome light with LEDs | svgimmeshelter
post #1436 of 1600 Old 09-23-2015
Barquito
Barquito's Avatar
I have the same setup. Most stern pulpits are not vertical, so make sure you have holes in the bottom of the pipe that are near the edge, not in the middle.
Valiant 32
Barquito is offline
post #1437 of 1600 Old 09-23-2015
SV gimme .Lubing the threads with suitable grease negates the need to find a pipe wrench while the BBQ cools. Drilling a hole in the cap for a bit of lanyard helps sometimes as PVC dosn't float too good
Capt Len is online now
post #1438 of 1600 Old 09-24-2015
travlin-easy's Avatar
Here's a video of my hatch doors, which were made by the boat's previous owner. He said the project took him less than a day to complete.
https://www.youtube.com/watch?v=Mrc4q2W74ps
Gary
travlin-easy is online now
post #1439 of 1600 Old 09-27-2015
pdqaltair's Avatar
Storm windows for Winter. Any ideas other than insulation?
For example, we swap bug screens for 1/8" polycarbonate. In may cases, it's as simple as tracing and cutting.
Some are a little harder to fit (the small Beckson hatch screens can be swapped, but it requires cleaning and swapping the gaskets).
How about external covers (other than canvas)? Keeping the UV off always helps, and covers can reduce the summer AC load.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #1440 of 1600 Old 09-27-2015
A source of thin clear plastic sheet is those huymongous TVs that are thrown out at the recycle depot (projecter type) Probably acrylic but the price is right.
Low-Buck Dinghies- Lets See 'em! bljones Gear & Maintenance 48 05-09-2013 04:30 PM
Lazy Jacks: Lov'em or Leave'em? Winderlust Sailnet.com Polls 44 04-02-2013 02:46 AM
