Low buck projects- Let's see 'em! - Page 152 - SailNet Community
 1315Likes
post #1511 of 1600 Old 03-03-2016
svsolaris's Avatar
Re: Low buck projects- Let's see 'em!
Another winter project almost completed. I made this cockpit table out of a free wood pallet and a $2.03 1.5x1.5 piece of wood for the frame. It's not perfect but looks pretty good if you ask me. The plan is to make the stand out of PVC pipe and flanges which I priced out to be about $15 from Home Depot. This way I'll have the table, leg and base so it all comes apart for easy storage. Need to get the tarp off the boat to measure the height so I can finish it up.
svsolaris is offline
post #1512 of 1600 Old 03-03-2016
looks real nice
fred1diver is offline
post #1513 of 1600 Old 03-03-2016
Barquito
Barquito's Avatar
Looks good. Does the flange base stay bolted to the cockpit floor? Just wondering what that part is going to look like. Overkill may be to use piano hinges for the table. Post some pictures when you have it in (maybe with some full beers).
Valiant 32
Barquito is offline
post #1514 of 1600 Old 03-03-2016
svsolaris's Avatar
Haha yeah I was fresh out of beers by the time I got that far! My plan is to find a solid wood base and mount the flange on it. Not fixed to the floor. Then another flange on the underside of the table which will be hidden by the frame. Hopefully I won't have too many issues with the table moving. I have a removable wood cockpit floor that I should be able to secure the base to. I'll have to see how it goes when I get that far.
I'll post the finished product with full beers and snacks when completed.
post #1515 of 1600 Old 03-16-2016
Took me a few days to read through this thread and I wanted to say THANK YOU to all the contributors! I'm 45 days from launch and I now have lots of inspiration for some small projects I can do to keep busy until then.
Barquito and Rhapsody-NS27 like this.
CurEuS is offline
post #1516 of 1600 Old 03-17-2016
WinterRiver's Avatar
The boards in the lazarette were falling apart, the plywood was disintegrating but the slats were still good wood.
The engine compartment panel had seen better days.
The door also needed some attention.
This was significantly easier than replacing the veneer, and sturdier too.
Cost: time, and the price of new (cheap exterior grade) plywood for the lazarette.
Rhapsody-NS27 likes this.
WinterRiver is online now
post #1517 of 1600 Old 03-17-2016
New boat cushions are crazy money, found some old caravan cushions, got the kitchen knife out......just got to persuade the wife to cover them now!
seabeau likes this.
Islander123 is offline
post #1518 of 1600 Old 05-06-2016
Wes
Auto pilot, low battery drain...fully adjustable via wing nut on the underside
Just broad reachin' through life...
Alberg 30/ #196 Griffin's Faith
Wes is offline
post #1519 of 1600 Old 05-06-2016
Wes
Modern adaptation of the old swing arm...
Rhapsody-NS27 and Minnesail like this.
Wes is offline
post #1520 of 1600 Old 05-08-2016
Here is a low buck pedestal guard + instrument pod under 100 bucks. I have a spare Raymarine Pathfinder display, so why not put it at the helm? Problem, no instrument pod and no place to put a pod. Solution:
1 - go to an exhaust shop, get them bend a piece of 1" ss tubing for dirt cheap.
3 - get two 1" stanchion bases that will support the guard.
3 - get measurements on the pedestal, draw the drawing in CAD and have a friendly water-jet cutter shop to cut a piece of aluminium that goes between the pedestal and the compass.
4 - from some scrap plywood, create the pod.
5 - measure at least 4 times and drill only once to install the bases and cut the hole in the teak grating. Success!
6 - still to come: paint the pod and install the instrument wiring.
Rhapsody-NS27 and seabeau like this.
szigi is offline
Low-Buck Dinghies- Lets See 'em! bljones Gear & Maintenance 48 05-09-2013 04:30 PM
Lazy Jacks: Lov'em or Leave'em? Winderlust Sailnet.com Polls 44 04-02-2013 02:46 AM
