Low buck projects- Let's see 'em! - Page 154 - SailNet Community
 1315Likes
post #1531 of 1600 Old 05-15-2016
Senior Moment Member
SloopJonB's Avatar
Re: Low buck projects- Let's see 'em!
Looks great, especially for a first effort.
It takes a few different pieces to start to get a feel for what will work best.
SloopJonB is online now
post #1532 of 1600 Old 05-15-2016
al brazzi
Thanks, I'm not looking for shine as much as corrosion resistance, these pieces are going to stand out a bit on an older Boat but if I don't polish them it will be ugly. Its nice to master a new skill, I'll get there.
albrazzi is offline
post #1533 of 1600 Old 05-16-2016
midwesterner's Avatar
I'm making repairs on my 1969 Chrysler Lonestar 16. I needed to tighten and repair the jib sheet cam cleats but they were installed on the deck before it was attached to the hull. I needed to remove the side cushions and make an access hole to be able to reach the nuts on the underside of the screws.
The side cushions are thin pieces of plywood covered with foam and vinyl upholstery. I will replace them.
midwesterner is online now
post #1534 of 1600 Old 05-16-2016
Pick up a small bench buffer at HF for $40 along with a stick of green compound. Wet sand the plates through the grits up to about 1000 grit or thereabouts then polish them with the green stick and the buffer - they'll look like chrome.
Then you have the buffer to keep your metal bits looking good for years to come.
Some samples before & after.
What do you use to corral those small and irregular parts as you minister to them to keep them from sliding all over the place?
seabeau is offline
post #1535 of 1600 Old 05-16-2016
SloopJonB's Avatar
Hang on tight! Wear gloves because it is a filthy process and the piece can get very hot as well.
Make sure you are only using the "down" part of the buff - it should always be moving away from you where it contacts the workpiece.
Very small parts like bolt heads can occasionally fly across the room but holding them with vice grips minimizes it.
seabeau likes this.
post #1536 of 1600 Old 05-16-2016
travlin-easy's Avatar
I use a pair of welder's gloves when high speed polishing metal parts, which not only protects your hands from the heated surface, but the gloves also protect you from injury when some parts go flying in the wrong direction.
Gary
seabeau likes this.
travlin-easy is online now
post #1537 of 1600 Old 05-16-2016
Gary
Like those high gauntlet style? To the elbows?
seabeau is offline
post #1538 of 1600 Old 05-16-2016
SloopJonB's Avatar
Can't hurt but I just use split cowhide work gloves. If you are doing small pieces you'll find the fingertips get worn through so it's better to not use expensive ones.
The stiffer the gloves are the more parts go flying as well - finger dexterity is important.
One other thing - it's best to do it outside. As I mentioned, it is a filthy process and the flying grime is waxy so it sticks wherever it lands.
post #1539 of 1600 Old 05-16-2016
That sound reasonable. I've got an old side grinder somewhere about but its industrial and might be too difficult to handle on small parts. I'll get some of those abrasive sticks and give that stuff a try. My old boat could use some "brightening up". Thanks.
seabeau is offline
post #1540 of 1600 Old 05-16-2016
al brazzi
I routed a recess in a piece of hardwood to hold my parts while using scotch brite pads, they can still fly out at times but it works pretty good. For the buffer, gloves.
albrazzi is offline
Low-Buck Dinghies- Lets See 'em! bljones Gear & Maintenance 48 05-09-2013 04:30 PM
Lazy Jacks: Lov'em or Leave'em? Winderlust Sailnet.com Polls 44 04-02-2013 02:46 AM
