Low buck projects- Let's see 'em! - Page 160 - SailNet Community
 1315Likes
post #1591 of 1600 Old 07-06-2019
Barquito
Barquito's Avatar
Re: Low buck projects- Let's see 'em!
Originally Posted by Locke View Post
That's a good idea. I'm more concerned about the location. The cockpit is fairly small and space is a premium. Although, with velcro I may be able to mount it in different places. I'll play with it this weekend while I'm out.
An arm that swings from inside the cabin, into the companion way works well. You may also consider mounting them on a board that replaces one of the hatch boards.
Valiant 32
Barquito is online now
post #1592 of 1600 Old 07-06-2019
TakeFive's Avatar
RAM mounts are great. Their suction cup rubber ball mount allows you to put something on virtually any smooth flat surface - companionway hatch, plexiglass port, vertical gunwale. I have a rubber ball permanently attached at the top of my binnacle for mounting my chartplotter for when sitting at the helm (or adjacent to the helm, since it can rotate 360 degrees around). When the weather turns bad, I put the suction cup under the dodger and move the chartplotter there. I also take the suction cup to others' boats to mount my stuff temporarily if doing a delivery or charter.
Minnesail likes this.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #1593 of 1600 Old 07-07-2019
I didn't know there were suction cup RAM mounts.....That would work great. I could move it around as the situation demands. I use a permanent base for one on my fishing boat. I like those Ram mounts. I'll see about getting one on my next payday. I just spent a lot more than I planned on for this last one.
Locke is offline
post #1594 of 1600 Old 07-11-2019
This is genius. What is the amp draw on the drill? Does it spike up high if the drill gets bogged down in tough material?
danvon is offline
post #1595 of 1600 Old 07-11-2019
Minnesail's Avatar
I've heard some people say they have a binary depth sounder their keel. Either they're aground or they're not.
Well, I have a binary amp meter. Either I've blown the fuse or I haven't. So I know that the drill draws less than 15 amps, but I couldn't say how much less. If it bogs down it does drop the voltage enough so that you can see the cabin lights dim.
Catalina 22
on a starboard tack
Minnesail is offline
post #1596 of 1600 Old 07-14-2019
That's a good enough answer for me. Less than 15 A should be fine.
danvon is offline
post #1597 of 1600 Old 01-02-2020
just working n a double jetboil burner gimbal, it's just a prototype at the moment, still trying to figure out how to fix it in the boat (75 Grampian 26)
ThereYouAre likes this.
I'm the new owner of a 1975 Grampian 26 in need of a lot of love.
previous boat was an Olympic Dolphin 23.
also like to go camping and scuba diving
Frederic Tremblay is online now
post #1598 of 1600 Old 01-02-2020
Props to you
But wouldnt a cheap 2 burner propane bottle camp stove be cheaper in the long run...
RegisteredUser is online now
post #1599 of 1600 Old 01-02-2020
already had a jetboil burner, was already thinking about getting another one (java model) so all that was needed was the wood, about 40$ and have plenty leftover for a few other projects.
I have a 2 burner stove, but it's a bit too wide for my galley and I wanted a gimballed stove
post #1600 of 1600 Old 01-02-2020
Have you calculated the centre of mass of a pot of clams on the burner?
Capt Len is online now
Currently Active Users Viewing This Thread: 18 (0 members and 18 guests)
Low-Buck Dinghies- Lets See 'em! bljones Gear & Maintenance 48 05-09-2013 04:30 PM
Lazy Jacks: Lov'em or Leave'em? Winderlust Sailnet.com Polls 44 04-02-2013 02:46 AM
