FG layup schedule to achieve desired thickness - Page 2 - SailNet Community
post #11 of 14 Old 01-16-2009
You're short two hulls, and a couple of cookies shy of a dozen. BTW, AFAIK, West Systems still forms an amine blush, although less of one, when you use the slow hardener.
Originally Posted by dgr View Post
SD,
Are you suggesting I do this from the inside? Next thing, you'll be telling my I'm short two hulls
Seriously, thanks for the pointers. Laying up while the previous layup is green was what I was hoping to do. I will definitely be painting my deck white or some other non-dark color.
sailingdog is offline
post #12 of 14 Old 01-18-2009
blue collar cruiser
soulesailor's Avatar
You should be able to get an accurate number of layers needed when you grind your deck in prep for the glass work. By grinding your deck glass back you will clearly see each of the layers in the laminate.
who is staring at the sea is already sailing a little
soulesailor is offline
post #13 of 14 Old 01-18-2009
FG layup
Ancient Chinese secret: Drill a core sample and burn it. The resin burns away and leaves the glass intact. Peel them apart carefully and you'll know exactly how your boat was built.
amunro is offline
post #14 of 14 Old 01-18-2009
dgr, call the folks at West Systems or go to their web site. They have this all documented in their archive of articles, and if you call their tech support department they'll help you figure out exact numbers and a layup schedule--even if you haven't bought any materials yet.
hellosailor is offline
How often do you visit your boat during winter layup? abrahamx Gear & Maintenance 59 11-30-2013 02:17 PM
winter layup in fl e37duff General Discussion (sailing related) 3 08-12-2010 09:11 AM
Starting Perkins 4-108 after long layup MIKEMCKEE Diesel 4 07-04-2010 09:21 PM
Restart Diesel After Layup TXS-ALAMO Gear & Maintenance 3 09-13-2006 07:23 PM
Hull layup Irwin32 Boat Review and Purchase Forum 2 06-22-2002 08:14 PM
