Tips For Compound, Polish & Wax - Page 32 - SailNet Community
 34Likes
post #311 of 330 Old 09-28-2017
Re: Tips For Compound, Polish & Wax
This Fabulous post was done in 2009. Do you still recommend the same products now that we are in 2017? And, what process would you recommend for Awlgrip stripes on hull?
Seamantha is offline
post #312 of 330 Old 12-25-2017
I touch up my hull every spring using same products. Hard to improve on what’s been shared. Good luck!
"There is nothing, absolutely nothing half so much worth doing as simply messing about in boats." Kenneth Grahame
oomfh is offline
post #313 of 330 Old 04-22-2018
What an amazingly detailed post. Thank you for sharing!
I just polished my hull with 3M Perfect-It 36105 Gelcoat Medium Cutting Compound/Wax. I was happy with the results, but it was definitely far from this incredible level of gloss. I think I'll take another shot at it next spring and maybe get it a little closer to something as amazing as this.
tristan35 is offline
post #314 of 330 Old 04-23-2018
travlin-easy's Avatar
I put my last coat of wax on the boat 4 years ago when I switched to Poli-Glo, which only takes me about a half hour to apply and looks fantastic all year long. This year, I'll strip the old coats of Poli-Glo from the hull with their special cleaner and begin anew. A friend of mine did that last week and his boat has a mirror finish now.
Good Luck,
Gary
travlin-easy is offline
post #315 of 330 Old 03-12-2019
How important is variable speed on the buffer? I don't have electric where my boat is currently stored so looking at a Ryobi battery powered buffer, but it's single speed (2500 rpm). Is that too fast? Oxidation isn't that bad, and the boat is only 24 feet so I don't plan on going all out, so maybe it's ok? Or is a single-speed so bad I should consider a towing the boat to a different location to do it? (or finding a generator, I'm not spending $800 on one..)
edit; nvm, think I'm ditching the idea of battery powered buffer. Gonna try one of the cheaper $400 generators. Also useful for power washer and other things.
Scandium is online now
post #316 of 330 Old 03-13-2019
Senior Moment Member
SloopJonB's Avatar
2500 is too fast - that's sanding speed.
For buffing & polishing you want about 1/2 that - 1200 to 1400.
SloopJonB is online now
post #317 of 330 Old 03-13-2019
TakeFive's Avatar
In my experience, electric power washers are almost worthless. Even a high power gas washer isn't as effective as a brush or wiping with a sponge. The only reason to use a gas power washer is ergonomics - you can wash the slime off the bottom of your boat in a standing or kneeling position, much more comfortably than brushing/wiping your boat's bottom from underneath, with slimy water dripping all over you and running down your arm. But for topsides, a pressure washer is far more trouble than it's worth (and can damage the gelcoat if you slip up and get too close).
Back to the main topic, I'd check the power needs of a plug-in buffer and consider an inverter. If a little plug-in one won't be enough, but they make bigger ones (400-600 watt) that can clamp onto a car battery. If you're on the hard, you could run your car motor to juice the battery while running off the inverter.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #318 of 330 Old 03-13-2019
I own a buffer but I rarely use it, arm muscles work fine.
paulinnanaimo is online now
post #319 of 330 Old 03-14-2019
SloopJonB's Avatar
You do your cut polishing by hand?
I usually do my waxing by hand but not the cutting compounds.
post #320 of 330 Old 03-14-2019
That sounds a bit intense.. I don't have power where my boat is now so I'm trying to find a way to use a buffer without spending $400+ on a generator just for that purpose. But don't think arm muscles is the answer. Maybe I just do full buffing in the fall instead.
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
Compound and Wax Hull near Det.? newpbs Gear & Maintenance 0 04-18-2012 09:49 PM
Presta Compound/Polish Products - Amazing! labatt Gear & Maintenance 5 07-07-2009 06:03 AM
Tips For Buff, Polish & Wax Maine Sail Gear & Maintenance 0 03-24-2009 03:25 PM
Compound and wax rate??? SiXeVeN Gear & Maintenance 7 02-01-2009 11:34 AM
Polish VS. Wax ddilman General Discussion (sailing related) 10 07-03-2006 04:43 PM
