Tips For Compound, Polish & Wax - Page 33 - SailNet Community
 34Likes
post #321 of 330 Old 03-14-2019
Re: Tips For Compound, Polish & Wax
Perhaps I was misleading about using muscle power. I have not let our boat get to the point of needing special attention. The hull is in good shape and a good going over twice a year with a cleaner/wax keeps it that way.
paulinnanaimo is online now
post #322 of 330 Old 03-14-2019
I should add that Scandium did say that his boat is 24', is not oxidized badly, and he isn't planning to 'go all out'. That, to me, suggests that moving the boat or buying a generator, to power a buffer that he does not have, is a lot of unnecessary expense and effort.
SloopJonB likes this.
post #323 of 330 Old 03-14-2019
Yeah that's what I'm thinking. Though I honestly don't know how to tell how bad oxidation is as this is my first time dealing with it.. And don't have anyone to ask. It is on a trailer so moving it isn't a huge deal. I'll probably get a $50 buffer and drive it somewhere to give the sides a once over. The deck etc I can do by hand. But like you I hope to just do a cleaner-wax by hand after a thorough first time. So want to avoid getting lots of tools I won't need again for a while
Scandium is offline
post #324 of 330 Old 03-14-2019
You can pick a small area to start and see how that goes.
post #325 of 330 Old 03-14-2019
Senior Moment Member
SloopJonB's Avatar
I wouldn't waste the $50 on a cheap buffer like this one
https://www.amazon.ca/Wen-10PMR-Waxe.../dp/B004TA06QA
All they do is vibrate your hands. Save it towards a good one for when you have power.
Sounds like a thorough hand applied cleaner/wax job - maybe a second coat of good quality carnauba would be the way to go now. Not much more work doing a 24' than a car.
In the described circumstances that's the way I'd go.
SloopJonB is online now
post #326 of 330 Old 03-14-2019
TakeFive's Avatar
I usually do my waxing by hand but not the cutting compounds.
Thatís the right way. If someone needs a buffer for wax, they havenít polished correctly...even if itís 885 Fleetwax.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #327 of 330 Old 03-15-2019
This tells me nothing, lol. Never waxed a car (it's a car, who cares? My boat on the other hand..)
Anyway. I worry, from my limited understanding, that just doing a one-step cleaner/wax now could risk "sealing in" the oxidation? There's a blue part on the side that's pretty chalky. But maybe doing a proper compound/oxidation remover next spring could easily get rid of it? Or a wax-remover first? And I guess there's the chance the one-step might actually be enough (though the OP here has no love for those, probably for good reason. At least he didn't 10 years ago..).
But as soon as water is turned on so I can clean it I'll hand-apply compound and wax a small area and see how it goes. It it's too big a PIA do a 1-step to the sides at least, since I can't do those once in the water. But you're right a 24' isn't that big.
Thanks
Scandium is offline
post #328 of 330 Old 03-15-2019
I do not intend to veer anyone off the track of the excellent advice in the OP. It's the way to go for perfect results. The last post seemed concerned about doing less, using cleaner/waxes, etc. To that I say, you really can't do much harm. Any cleaning and protection is better than none. Personally, I would shy away from any that actually coat or paint the fiberglass. If anything doesn't come out as good as you like, it needs to be able to be easily removed. Even wax can build up, so any good cleaning should start by removing the old wax. Wax is very easily removed with the right detergent.
Jeanneau 54DS
Minnewaska is offline
post #329 of 330 Old 03-15-2019
Scandium
Cleaner/wax is a good idea but not for removing oxidation. If you go back to the beginning of this thread the advice given for removing oxidation is rubbing compound and/or wet sanding. There are a multitude of additional steps but you have to decide how much effort, money, and time you are willing to invest. Keep in mind that some of the great advice given here is coming from sailors that own boats that are worth many tens of thousands of dollars...their perspective may not be the same as yours.
post #330 of 330 Old 03-15-2019
TakeFive's Avatar
Originally Posted by Scandium View Post
...There's a blue part on the side that's pretty chalky...
Thanks
If you have a chalky dark blue boot stripe or similar, you may have to wet sand. I've done this on two separate boats using 2000 grit sandpaper with spray bottle with a little detergent in the water, and it has always restored the deep blue color. After the wet sand, do your polish like you'd do on the white part of the hull, and finally the wax.
For both of my boats I've always done a one-step with Presta Ultra Cutting Cream, which is one of the things that Maine Sail suggested. It starts out a coarse compound, and breaks down as you work it (using electric polisher) to a fine polish. It's worked very well for me.
I went several years with a cheapo Harbor Freight polisher, but got tired of the speed running away every time it heated up, so finally got smart and got a Makita variable speed which is rock solid at the needed slow speed setting.
TakeFive is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Compound and Wax Hull near Det.? newpbs Gear & Maintenance 0 04-18-2012 09:49 PM
Presta Compound/Polish Products - Amazing! labatt Gear & Maintenance 5 07-07-2009 06:03 AM
Tips For Buff, Polish & Wax Maine Sail Gear & Maintenance 0 03-24-2009 03:25 PM
Compound and wax rate??? SiXeVeN Gear & Maintenance 7 02-01-2009 11:34 AM
Polish VS. Wax ddilman General Discussion (sailing related) 10 07-03-2006 04:43 PM
