composting toilet report - Page 20 - SailNet Community
 45Likes
post #191 of 443 Old 04-21-2010
remetau's Avatar
Originally Posted by GilStump View Post
We liveaboard. We partially empty ours every two weeks into a biobag and toss it in the garbage. The remainder starts "cooking" the new stuff. If we had one of them weirdo land housey things, we'd start a composting pile. As it is, I don't feel too bad about 3 gallons in a bag that will biodegrade and let our #2 combine with all the diapers and banana peels and rotting carcasses leftover from the weekends BBQ. And if we ever get our old boat 3 miles offshore, bloop!
If you are tired of the stench of old hoses and the extra hole in the boat, and the nasty nasty holding tanks, get one. It rocks.
I probably will get one eventually. I'm just trying to figure it all out and justify the cost of a plastic bucket with a toilet seat on it.
Don & Diana
sv Re Metau an HC33t
remetau is offline
post #192 of 443 Old 04-22-2010
bellefonte's Avatar
why is that?
Originally Posted by RXBOT View Post
leave compost in finishing drawer for 3-4 weeks
That doesn' seem practical for a live aboard couple.
Would you need to empty the finishing drawer more often than the manufacturer recommends?
If so, why?
Of anyone that has installed one, I have not heard that this is an issue.
My Cruising blog:
But it's not who you are underneath, it's what you do that defines you. ... Rachel Dawes
bellefonte is offline
post #193 of 443 Old 04-22-2010
The US EPA has a PDF file online about composting toilets. No pun intended, but the "bottom line" is that most of what are being sold as composting toilets for boats? Aren't.
The EPA recognizes two kinds of composting toilets. One, where the waste gradually fills a bin so that what you are removing is typically a year old, as it progresses down from the toilet. After a year in the proper conditions, it has composted and is no longer hazardous sanitary waste.
The other, requiring AT LEAST TWO BINS or composting units. You use one, the either swap it out or move ot the other, and ALLOW THE FIRST BIN TO COMPOST for at least a full month. Longer depending on conditions.
So...composting toilet for boats? Unless you have two of them, or two bins and space to swap them out, it is nothing more than a cedar bucket with aspirations to be something more. And what comes out of it, is still "sanitary waste" that requires the appropriate permit and special handling to be disposed of, or buried, ashore.
I know, waste is waste and a "dry head" may still be more convenient than a holding tank full of wet waste. But as far as I can see--the things being sold as composting toilets, for single installation on boats, just aren't going to generate any kind of sterile safe compost.
Of course, they're way easier to find than plain old cedar buckets. :-)
hellosailor is offline
post #194 of 443 Old 04-22-2010
bellefonte's Avatar
perhaps the old traditional holding tank is replaced with a "holding bin" (also vented) that partially composted peat and waste is moved to until it composts fully.
Just a thought.
If it can be done late enough in the process, its shouldnt be too hard to manage. Still preferable to a wet storage I would think.
My Cruising blog:
post #195 of 443 Old 04-22-2010
Replace it with two holding bins, each with a liquid separator, and you've got a valid composting system. Just remember--each bin needs to have temperature and ventilation and liquid separation managed, and be large enough to hold all your waste for somewhere between one and three months to allow that compost time to ripen.
I'll go with a holding tank, and peeing in a urinal. (Ladies, turn away. Sometimes men use the sink.)
post #196 of 443 Old 04-22-2010
blackjenner's Avatar
Do you have a link to that PDF? It would be very useful.
"There's nothing . . . absolutely nothing . . . half so much worth doing as simply messing around in boats." -- Kenneth Grahame, The Wind in the Willows (River Rat to Mole)
1980 Baba 35 Pilot House Cutter - Brigadoon
blackjenner is offline
post #197 of 443 Old 08-15-2010
Sunsets and Warm Beer....
LandLocked66c's Avatar
So now that summer is underway and approaching Sept. What's the word on the composting toilets? Stinky or better than sliced bread?
You can't steer a boat that isn't moving? Just like a life - P. Lutus
LandLocked66c is offline
post #198 of 443 Old 08-15-2010
non-stinky
Chronology:
- installed Nature's Head in spring
- used by two guys for two weeks continuously
- used by me weekends thereafter
- I neglected to put a screen on the vent hose and got a fruit fly infestation
- emptied and cleaned the solids bin (it sat unused for two weeks prior) smelled like potting soil ... put the compost in my compost pile at home
- if I didn't get the fruit flies, I would still not need to empty it
- I basically live at the Marina most weekends - definitely don't miss the pump-outs!
- would definitely do it again!
RonRelyea is offline
post #199 of 443 Old 08-15-2010
Unpaid Intern
josrulz's Avatar
Originally Posted by RonRelyea View Post
Chronology:
So did you end up using your existing vent hose outlet for the holding tank as planned? If you don't mind me asking, where is that vent, and where is your head in relation? We're very interested in installing a composted head this winter, but I'm still trying to work out the logistics of how we would install our nicro vent or use the existing vent line, so I'm very interested in how others have done the project.
Thanks!
-J
1984 Sabre 34 Mk I
josrulz is offline
post #200 of 443 Old 08-15-2010
Composting Head vent
J
I originally vented the head through the old holding tank vent but found that to be too restrictive. Now I've got it vented through the holding tank deck pump-out fitting. I dremeled out the center of the fitting's cap and hot-glued screen onto it. I get a small amount of rain water through the screen and down the hose which is easy to deal with. I use the built in fan on the Nature's Head.
Total run for the vent hose is about 10 feet ... I'll get pictures next time I'm down to the boat.
Air Head Composting Toilet or Similar Mfg. kjzerr Gear & Maintenance 164 03-09-2015 01:37 AM
Air Head Composting Toilet arf145 Gear & Maintenance 32 09-16-2014 04:49 PM
composting toilet-should we do it CLOSECALL Gear & Maintenance 87 02-25-2014 08:51 PM
Airhead composting toilet rwh Living Aboard 1 08-22-2003 07:57 AM
Airhead composting toilet rwh General Discussion (sailing related) 2 04-08-2003 04:55 AM
