SailNet Community (https://www.sailnet.com/forums/)
-   Gear & Maintenance (https://www.sailnet.com/forums/gear-maintenance/)
-   -   3g/4g connectivity (https://www.sailnet.com/forums/gear-maintenance/60472-3g-4g-connectivity.html)
QuickMick 12-11-2009 03:52 PM
3g/4g connectivity
Any of you guys found a reliable global network for ship board pc access regardless of local? if so, how much... that part of the question is always the humdinger...
have a great weekend,
Quinn
danielgoldberg 12-12-2009 09:59 AM
Truly "global"? To my knowledge, the only option is satellite, which is not cheap, depending on what you want to do and what your definition of cheap my be.
But in the U.S., if you can get a cell signal, then using one of the retail broadband aircards is a very viable and reasonably-priced option. I've used AT&T, which has worked fairly well (AT&T's service for voice is very spotty, but I've found that for data, such as a Blackberry and aircard, it works fine). I'm sure Verizon's service is great, and probably better than AT&T, but I haven't used Verizon data service.
Outside the U.S, but still in cell range, such as Batelco in the Bahamas of something like that, I bet you can buy a prepaid SIM card and plug that into your aircard. I've never done that, but I suspect it would work.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
