Sea Water Strainer - Page 2 - SailNet Community
 6Likes
post #11 of 15 Old 10-20-2015
Re: Sea Water Strainer
Losing prime after cleaning can't happen if below wl. Checking thruhull ingress is possible too. Not so if above. At least the sea valve gets tested, which is good. The raw water pump is often below wl so a failure there is either direct from ocean or syphon over thru the strainer No matter .thats what the valve is for.
Capt Len is online now
post #12 of 15 Old 10-21-2015
al brazzi
Originally Posted by overbored View Post
if you loose prime then you have an air leak. if the strainer and all piping are completely sealed it make no difference where the strainer is in the line. it is just a fat section in the pipeline. because it is on the suction side of the pump you can have a leak that will let air in and will not leak water out.
Right, as long as the Motor is running. Below the water line it will do both but at different times. That suction leak will turn into a real leak if the leak is below water line. From a point of view that the strainer is the most likely source of failure you may choose it put it above the WL but then again it might just not be practical. Choices..
albrazzi is offline
post #13 of 15 Old 10-21-2015
JimsCAL's Avatar
Wow, a 12-year old thread and no one notices!
JimsCAL is online now
post #14 of 15 Old 10-22-2015
Send a message via Skype™ to doctorcam
Or cares? ;-)
Timely for me, regardless - I'm about to replace everything from the thruhull inward, engine included!
Albin 79 "Catharsis" - moored in Whiskey Slough, Pender Harbour
doctorcam is offline
post #15 of 15 Old 10-22-2015
Jim, probably everyone noticed. Boaty problems and opinion of solutions remain constant .It's the viewing public that changes.
asdf38 likes this.
Sea water strainer for engine intake - flat jarcher Gear & Maintenance 11 07-08-2010 06:56 AM
Sea water strainer Install mogul11 Gear & Maintenance 8 05-12-2009 09:39 AM
Sea Water Strainer Clean Frequency for Diesel DrB Gear & Maintenance 3 07-20-2007 05:49 PM
sea strainer location and plumbing? e31 Gear & Maintenance 2 10-01-2004 11:36 AM
boats with easy engine, seacock, sea strainer, etc access night_raver Boat Review and Purchase Forum 3 08-26-2004 10:11 AM
