Bedding Deck Hardware With Butyl Tape - Page 41 - SailNet Community
 69Likes
post #401 of 446 Old 10-07-2015
mitiempo's Avatar
Re: Bedding Deck Hardware With Butyl Tape
Originally Posted by MikeK2B View Post
I'm getting ready to pot and rebed my life lines and other miscellaneous hardware using Maine Sail's method (and his butyl tape). Does anyone have any experience with System Three's SilverTip GelMagic epoxy. I was wondering if this will work the same/as well as the outlined West Systems 105, 205, and 406 in your article?
SilverTip GelMagic - System Three Resins, Inc.
Thanks in advance for any feedback.
It will work the same as thickened West epoxy. But for potting holes you want liquid epoxy first, followed by the thickened epoxy. West or other epoxy that is liquid when mixed, then thickened later would be a better choice.
The GelMagic epoxy seems to be System Three's answer to West Six/Ten cartridge epoxy.
Brian
mitiempo is offline
post #402 of 446 Old 10-08-2015
Great feedback, thanks. Despite reading Maine Sail's how-to several times, I wouldn't have realized my mistake until I was in the middle of the process. Thanks!
MikeK2B is offline
post #403 of 446 Old 10-19-2015
Great tutorial! Just ordered some,need to start rebedding deck hardware. Could this be used for resealing acrylic to hatch frame? I know there is no clamping force holding it in,but the pictures on pbase of the knife make it look very sticky and pliable. Not sure what the sealant is in the hatch frame now,but it is soft and pliable,and I suspect original to my 1982 boat.
DenS is offline
post #404 of 446 Old 11-14-2015
I might add that on a hot summer day butyl tape can be brutal to work with because it stretches so easy.
jgragrg is offline
post #405 of 446 Old 11-15-2015
TakeFive's Avatar
That's true of the cheap stuff from the RV store. But not true of the material that Maine Sail sells. Spend the money to do it right the first time. You won't regret it.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #406 of 446 Old 11-17-2015
al brazzi
That's what was used on my hatches. The thing I don't understand is why they used Black on all the hatches and white or off white on the hull deck joint. Cleaning all the excess off as I go but why Black on deck??
albrazzi is offline
post #407 of 446 Old 11-18-2015
TakeFive's Avatar
Are you sure they didn't use a curing adhesive/sealant, like Sikaflex 295? That's very common for around hatches, etc. It's totally different stuff from the butyl tape.
Carbon black pigment has well known properties as a free radical scavenger, which when formulated into sealants, rubber leg ends, wire ties, and other products can make them much more UV resistant. That's why you often see black sealants used in high sun areas. The white stuff works fine in more shadowed areas like hull deck joints.
TakeFive is offline
post #408 of 446 Old 11-18-2015
al brazzi
Carbon black pigment has well known properties as a free radical inhibitor, which when formulated into sealants, rubber leg ends, wire ties, and other products can make them much more UV resistant. That's why you often see black sealants used in high sun areas. The white stuff works fine in more shadowed areas like hull deck joints.
Its soft like Butyl that's why I think its that. AFIK all other sealants have a cure, this peels right off with a putty knife and cleans up with acetone. Curious I admit.
Yes I don't even but the white ties for that reason.
albrazzi is offline
post #409 of 446 Old 11-18-2015
mitiempo's Avatar
Butyl is not the best choice for sealing acrylic in a hatch frame.
The best choices are Dow 795, GE SG 4000, or Sika 295. The Sika requires a primer.
Which Sealants To Use | Selectplastics
Brian
mitiempo is offline
post #410 of 446 Old 11-19-2015 Thread Starter
Super Moderator
Maine Sail's Avatar
I don't recommend it for lens to frame unless it was an emergency fix to "get you home".. The proper sealant for hatch lens to frame would be a product such as Dow 795 of Sika 295UV with the special primer.
Frame to deck is fine but lens to frame I don't advise...
______
-Maine Sail / CS-36T
Maine Sail is offline
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
Bedding Deadlights w/ Butyl tape, DC795 and Screws mmazour Gear & Maintenance 12 01-20-2016 07:01 AM
Bedding bare teak with butyl tape? (Maine's Bed-It) Tanley Gear & Maintenance 1 06-04-2015 08:40 AM
Re-bedding Windows: 3M-4200 v. Butyl Tape saildork Gear & Maintenance 16 04-13-2011 03:08 PM
Butyl Tape fer hardware sealing fun! Skipper Joe Gear & Maintenance 10 04-18-2008 01:33 PM
Re-bedding deck hardware drynoc Gear & Maintenance 6 11-02-2003 05:00 AM
