Bedding Deck Hardware With Butyl Tape - Page 45 - SailNet Community
 69Likes
post #441 of 446 Old 11-14-2018
Re: Bedding Deck Hardware With Butyl Tape
Originally Posted by Minnewaska View Post
Yes, you should. Maine Sail who started this thread, sells it on his website. The link is in the OP. Not only are you assured of getting the proper quality, but I think he deserves the business for having provided the free value of the instruction in this thread.
I've purchased several rolls from him. I admit, I did purchase some hardware store variety to make a temporary sticky plug that I could remove on a project. It was intentional to have something cheap and disposable. It was clearly an inferior product.
I agree. I had bought some butyl tape from an RV store (on Amazon, I think) and it was kind of OK. Then I bought from MaineSail and I much prefer that one. A roll lasts a long time but when I run out I will surely buy from him again.
MastUndSchotbruch is online now
post #442 of 446 Old 11-14-2018
jvlassak's Avatar
In Maine's description of how to use the butyl tape to bed hardware, he points out not to turn the bolts when tightening the nuts. What if the bolts screw into a backing plate and there is no choice but to turn them? Is butyl still recommended in that case? Background: I need to rebed a couple of stanchions that are attached with bolts that screw into backing plates that seem to be embedded in fiberglass. Thanks -
1995 Pacific Seacraft 34
Iphigenia
jvlassak is online now
post #443 of 446 Old 11-15-2018 Thread Starter
Super Moderator
Maine Sail's Avatar
Make the "cones" a bit longer, really knead them into the threads and tighten slowly....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #444 of 446 Old 11-15-2018
jvlassak's Avatar
Thanks, I'll try it out. I still have some of your tape lying about.
Iphigenia
post #445 of 446 Old 04-08-2019
Sailnet Vendor
jblumhorst's Avatar
Location: San Francisco Bay area and West Coast by trailer
Dock
What is the "best practice" for installing Beckson Deck plates? I don't know if they're ABS or Polypropylene plastic or ???
Can I use Bed-it butyl with Beckson Deck Plates? They are on the top of the amas (floats) on my Trimaran. The prior owner used some kind of silicone sealant, which didn't adhere to the trim ring at all.
Thanks.
Judy B
San Francisco Bay and Delta
F24 Trimaran
jblumhorst is online now
post #446 of 446 Old 04-08-2019
al brazzi
I would use a non hardening caulk like lifecaulk, you absolutely done need 4200 or god forbid 5200 3M but there are lots of non silicone marine caulks available. Butyl requires you "squish" some out while tightening so its not suitable for softer fittings such as this.
albrazzi is offline
Currently Active Users Viewing This Thread: 32 (0 members and 32 guests)
Bedding Deadlights w/ Butyl tape, DC795 and Screws mmazour Gear & Maintenance 12 01-20-2016 06:01 AM
Bedding bare teak with butyl tape? (Maine's Bed-It) Tanley Gear & Maintenance 1 06-04-2015 07:40 AM
Re-bedding Windows: 3M-4200 v. Butyl Tape saildork Gear & Maintenance 16 04-13-2011 02:08 PM
Butyl Tape fer hardware sealing fun! Skipper Joe Gear & Maintenance 10 04-18-2008 12:33 PM
Re-bedding deck hardware drynoc Gear & Maintenance 6 11-02-2003 04:00 AM
