SailNet Community (https://www.sailnet.com/forums/)
-   Gear & Maintenance (https://www.sailnet.com/forums/gear-maintenance/)
-   -   Waterproofing/protecting wood (https://www.sailnet.com/forums/gear-maintenance/65166-waterproofing-protecting-wood.html)
wind_magic 05-31-2010 12:41 PM
Basic question ..
What do you usually use to waterproof wood ? I'm not talking about wood on deck that will be exposed to the elements all the time, or even anything external, I just mean oil or something you can put on a piece of wood so that it doesn't absorb water from spills when you are making dinner, that kind of wood protection. :) I just want the water to bead up and not stain the wood. I usually use tung oil in woodworking, but it is pretty pricey.
Thank you in advance!
bljones 05-31-2010 01:43 PM
Season new unfinished cutting boards and countertops with edible cooking oil, like corn or vegetable oil (but not olive oil). Rub it in three times a day for the first three days, and then re-season the surface every three months or so depending upon how often it gets wiped/ washed down.
PorFin 05-31-2010 01:46 PM
Originally Posted by wind_magic (Post 608614)
Basic question ..
Wind,
I'd personally stay away from any tung oil based treatment for any food prep area -- tung oil's pretty toxic.
Walnut oil is a good sealer, and can be rubbed in very well. You can buy it prepared/extracted, or you can simply get busy cracking walnuts and wrap the meat in a piece of cloth and extract the oil yourself. We used to use leftover Xmas holiday nuts to oil wood pieces.
Another alternative is to use a wax -- Johnson's will do the trick.
wind_magic 05-31-2010 03:49 PM
Thank you for the tips! Those are good suggestions. :)
I will let you know how it turns out
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
